Hi Drasko,
Your video shows very good dynamic range with the Slog2. Did you have to recover highlights in davinci or this is the way it was baked in th camera? What setting did you use to shoot against the sun? Any filters?
Thanks for sharing :)
yes recoverd highlights and shadows in davinci, the information is all there when you film with slog2
didn´t use a nd filter, i used F8 and had to set the shutter very high, wouldn´t recommend that though only if you have to
i will make a new test soon with the samyang but without slog 2 and not against such bright light
