I think you did quite well, didnt babble on too much, told us most of what we need to know, could have a few more shots and a bit more info but well done buddy it wasnt half bad for what it is, nice one.
p.s. thank god it leaves things in the centre of the "farm",  :lol: haha, :)
@foto-fanatic, thanks! and thanks for catching the typo, ha. Really ought to do more proof reading :P
Like most of you here, I really enjoy reading real-world tests and reviews. I love DXOMark as much as the next gear freak, but I always value a peers opinion and use case (:
Thanks for your review! Very good lens for a small price....What I find a bit disappointing is that it's FULLY manual....no aperture control, no EXIF Information in Files...
When you can live without that...get that stuff! ;-)
By the way...in other countries "Rokinon" is sold as "Walimex" or "Samyang"....it's all the same...
@matteo, thanks for the additional info. I knew about the Samyang branding, but hadn't heard of Walimex. Regarding the EXIF data--you're right it can be an inconvenience not having aperture data in files, but ISO and shutter speed do remain, which is of some help!
I shoot with some similar lenses, and
I never miss the aperture info in the
exif report. Hardly need it with a lens
that wide. These lenses out resolve
24mp sensors, and DOF is anywhere
from huge to endless. No need to be
specific about exactly which f-stops
are accomplishing these things, or at
least thaz true for my f/3.5 lenses. I
spoze if you can open up to f/2.0 then
maybe it can be good to check that a
frame is at f/2.0 or 2.8 or 3.2 etc.
@golem, I'm right with you on that one. Generally, things are all in focus unless you really open it up--then there are certainly chances to shoot and miss. That being said, with mirrorless missing focus is easily avoided. After using this lens, I may consider the Rokinon 14mm 2.8 FE for when I get my a7rii, but will have to do more research first. I fear something that wide will suffer from too much distortion to be practical. Also wonder how it will resolve on 42MP sensor.
......... I may consider the Rokinon 14mm 2.8 FE
It is pointless to wonder or worry how a lens
might resolve on a hi rez sensor. Resolution is
not the main ingredient in an image. It will be
just fine. Nobody ever hadda test their lenses
to see which one were suitable if they got the
notion to shoot some Pan-X or K-25. They just
went and DID it.
As to whether the 14mm will "will suffer from
too much distortion", only you can say. You've
got three parts of that phrase that only YOU
can define [or that each user must define for
themselves]:
1. "suffer"
2. "too much"
3. "distortion"
Numbers 1. and 2. are obviously subjective.
But number 3. .... "Distortion". All photos
are distorted. No exceptions for lenses that
may have excellent rectilinearity. Perhaps
you're questioning not distortion at all, but
wondering if the perspective rendering will
be too extreme for your use.
Consider such ideas as 42mp plus extreme
wide view, for architecture etc, means you
can crop instead of needing a shift lens.
You'll still have 25 to 30mp to print from.
IOW it's not an expensive lens, so get it.
Nice review. One of the most popular applications of this lens is astrophotography- it excels and punches above any APS-C e-mount lens regardless of price.
One issue I have with your review is your negative comments on the Sigma 19. The two lenses are very different, but overall I find the Sigma to be nearly as sharp as the Rokinon. One area where the Sigma beats the Rokinon is colors. I was shooting with both lenses today and the results from both were great.
Fair enough. I do love the way Sigma lenses [typically] capture color. After all, my favorite lens of all time remains the Sigma Art 35 (:
Samyang 12mm/2.0 is an amazing lens for the money with just two caveats:
1. Build quality and quality control. Mine came decentered. One side always softer than the other. I half dissassembled it, found nothing to be adjusted and reassembled it. That miraculously fixed it and it's been fine ever since.
2. Doesn't work in winter! At sub zero temperatures (I mean <0°C) the focus ring becomes so stiff it's almost impossible to move. The colder the stiffer. Even at temperatures still well above freezing it's much stiffer than at normal summer temperatures.
Regarding names, the company that makes this lens is called Samyang. Other names (Rokinon, Wallimex, Bower and some others) are different brands/resellers.
Miran, interesting tidbits. I'll have to try it out when cold weather comes!
On a side note, I just stuck it on my a7rii for the first time and have used it in crop mode (18mp). I love it on this camera! Great manual option when 18mp will suffice!
Another thing I noticed is there is Glare
(from shooting sundown and street lights)
on this lens? even with lens hood... Is there
way around it besides editing software?
No lens, of ANY focal length, will show
less glare from use of a lens hood ...
when the light sources are in the frame.
When the light sources are outside the
frame, then a hood can be very beneficial
but the benefit diminishes greatly as the
field of view widens. Lens hoods for ultra
wide lenses are basically just decorative
"pro-look" chzatkes. If you're a working
photographer it might help impress clients.
went and DID it.
themselves]:
1. "suffer"
2. "too much"
3. "distortion"
Why put a cheap lens with such a resolving sensor?
Cuz it works just fine. You seem in thrall to myth.
Re-read the post to which you've replied. Also try
researching the difference between rendering and
resolution. They are related, but are not the same.
Miran,
Whoa. You should have your lens checked out and possibly warrantied. I used mine quite a lot last winter - in Vermont, where the average temperature in February was around 0 F! I had absolutely no issues with moving the focusing ring when it is stupidly cold out. The Sony battery - that is another (and different) issue!
Albert
  • 2 months later...
