Black Posted February 17, 2018 Share Posted February 17, 2018 Hello there, i am a new member of this forum. Just wondering if anyone can give me a suggestion. I tested my Sony a7ii with MF Canon FDn 500mm f/4.5 L lens, mounted on a CF tripod (Sirui N-2204), steady shot set at 500mm then shot on and off both mode, shutter speed around 1/800 to 1/1500 but can not get a sharp image. I even can see on the magnified LCD (without touching anything) the picture is not stable, kind of vibrating. Is it camera problem or Tripod? Please help me.Thank you. Link to post Share on other sites More sharing options...
Advertisement Posted February 17, 2018 Posted February 17, 2018 Hi Black, Take a look here Sony a7ii with Canon FDn 500mm f/4.5L focus issue. I'm sure you'll find what you were looking for!
Username Posted February 20, 2018 Share Posted February 20, 2018 ` You're using a minimal shutter speed and your rig is vibrating. I have no idea what the model name on your tripod means but mine is leftover from my 4x5 and 8x10 cameras and goes nine feet tall ... IOW, the legs and head are massive. And I can see vibration when using the MF magnifier with long lenses or long extensions. But I use electronic 1st curtain shutter and acoarst wireless remote and have no sharpness issues. If you insist on using such shutter speeds, you also ought to support the camera-plus-lens combination both at the camera and at the lens. I use one hard connection [body or lens collar] and one padded "gravity rest" without a hard connection. Two hard connections would vibrate worse. Rigidity invites vibration. Friction damps vibration. The padded "gravity rest" avoids too rigid a setup. It's almost certain that your tripod is lighter than what I use, so if you're taking fewer precautions than I do, you'll have trouble. ` Link to post Share on other sites More sharing options...
Yeti Posted November 9, 2018 Share Posted November 9, 2018 It is my experience with Canon's 300mm/4 & 400mm/4 DO, that IBIS is not as efficient beyond 300mm+ focal lengths as lens based IS. I invariably prefer to use IS. Also, on a firm and stable platform (tripod) IBIS is supposed to be off. That's a fine lens you have but could be it requires focus adjustment to match your body or some element inside had moved out of alignment over time. Link to post Share on other sites More sharing options...
