adwb Posted January 20, 2016 Share Posted January 20, 2016 I have my A7R2 in air plane mode to save on battery power but what else is sucking the battery down when not in use and switched off? does any one know how long memory, copyright info etc is stored if the battery is out? is it stored on a eprom or is there a backup battery inside ? Link to post Share on other sites More sharing options...
Advertisement Posted January 20, 2016 Posted January 20, 2016 Hi adwb, Take a look here battery drops ovenight. I'm sure you'll find what you were looking for!
LiveShots Posted January 20, 2016 Share Posted January 20, 2016 It might be the EVF, I wonder if that sensor is being powered all the time. Link to post Share on other sites More sharing options...
AndyWear Posted January 21, 2016 Share Posted January 21, 2016 My A7 sucks battery all the time for some reason too. But I think it might just be the battery. Even when not in the camera, it always tend to drain. Link to post Share on other sites More sharing options...
adwb Posted January 21, 2016 Author Share Posted January 21, 2016 I have 4 batteries the two that came with and two third party ones, they all hold their power for days and if fitted a week after charging show 100-95 % full so it's not the my batteries self discharging, I am going to leave the camera battery less and see what happens to stored info like the date and location Link to post Share on other sites More sharing options...
Guest Peter Kelly Posted January 21, 2016 Share Posted January 21, 2016 Do you have a grip attached and, primarily, what is the make of grip? The only time I have had issues with battery drain is when the Meike grips are attached. However, if having them attached is the reason, the base cause might be either a poor implementation by Meike, or some bad protocol from Sony. It would be interesting to see if we could survey owners to find a possible cause, if not a solution! Link to post Share on other sites More sharing options...
adwb Posted January 21, 2016 Author Share Posted January 21, 2016 no grip for this one , I had one for the A7 but that went with the body, although I think the battery discharge is pretty much the same Link to post Share on other sites More sharing options...
Guest Peter Kelly Posted January 21, 2016 Share Posted January 21, 2016 That's interesting to hear and exonerates Meike! I'll try mine for a while without any grips and see what happens, although it'll be a good few days to know as I will probably be shooting regularly. Link to post Share on other sites More sharing options...
adwb Posted January 21, 2016 Author Share Posted January 21, 2016 i seem to remember i had my grip switched off , battery still power the body but the grip controls and the hand remote [ which I miss] did not Link to post Share on other sites More sharing options...
