I know this isn't an Alpha or NEX body but its still E Mount.
Write up - Some old summer elite footage that I never had any intention of posting, I shot this game a few weeks after I bought an FS5 from a friend. Everything is 240fps with the end trigger function.
Picture profile if I remember correctly was HLG 2, Rec 709 exposed at 80 Ire. Lens was the Sony 70 - 300mm FE G lens.
Definitely hoping the A7siii has some sort of start trigger/end trigger cache function.
  • 3 months later...
5 hours ago, VTC said:
Had to mute the 'porn' music. I never find myself muting actual (or simulated) field game audio. (If the viewer mutes the audio... it's scored wrong.)
Ok boomer. ?
Sweet ophelia by Zella day (Gold Fields remix) is a classic summer track.
Edited by MakoSports
unfinished
Hi! The quality is just great! Is this recording in 1080p to SD and after upscale to 4K ?
    • Hi Guys, I have a Sony a6000 bought second hand. It's working fine but the photo capture from video function in the playback menu is missing. I've updated the firmware to 3.21 from 1.00 but the option is still missing. I can now shoot in XAVCS but would like to grab still images from the video. Anyone please?
    • Some questions to help you formulate the answer to your own question: In what sense do you feel your 70-350 is lacking? What do you hope to gain from this 'upgrade'? What % of your shots are in the 70-200 range? If this % is significant, the 200-600 is not an option unless you carry two cameras or don't mind lens swapping. What % of your shots is at 350mm and potentially could have benefitted from more reach? Do you need high resolution shots or is cropping in post an option to fix your compositions? Would carrying a lens over twice as big and over 3 times as heavy have a negative impact on your photography (think of fun, mobility, physical strain, packing volume)?
