Considering going from a6000 to A7II...
RMorgan
This is my first post as I am a brand new member...
I have an a6000 which I purchased a couple of years ago as my first "real" camera.  As I continue to use it and get better with it I am beginning to consider moving up to a full frame camera and am curious about how much of a difference I'll notice going to an A7II.  Any feedback from folks with some insight would be appreciated.  I take mainly landscape and nature shots with occasional auto racing shoots and I am using using Sony lenses exclusively so far.
The A7ii is way better for landscapes, stills and portraits. Because of it's full frame sensor, it can capture more detail and retain sharper images after edits.
But, the a6000 is better for capturing action because of its higher Auto-Focus (AF) points. it has 179 while the a7ii stands at 117 AF points.
The a6000 also has a higher burst rate. It can take 11 photos per second and the a7ii can only do 5 photos per second.
Spec sheet linked below...
https://cameradecision.com/compare/Sony-Alpha-a6000-vs-Sony-Alpha-7-II
Hope this Helps!
