S-log3 and LUTs advice?
Hi - I've just got a Sony A7S mkii, and I'm struggling to figure out the picture profiles.
I'm using the camera in movie mode, with pp1 set to black level +1, gamma S-log3, and colour mode S-gamut3.
I use Final Cut Pro X, and I've downloaded a demo version of Color Grading Central's LUTs.
This contains around 40 different plug-in LUTs.
What I'm looking for is something that matches the beautiful look I get with my Canon 5d mkiii, with contrast and sharpness as low as they go, saturation one step up from that, saturation at zero. this is beautiful even before grading.
I'm looking for a mellow, 'cinematic' feel like film stock.
Also, I have a huge amount of noise in the s-log3.
Can anybody suggest some LUTs I could try that would look similar to the Canon image?
Thanks, any suggestions welcome.
Hi. I have only really been shooting in slog3. I find it fine except for some banding in highlights. The absolute secret is to overexpose your shots by 2 x stops or more. I set the zebra to 100 to protect from clipping. Anything less than 2 x stops over and the picture will buzz with noise.
During tests with a macbeth colour chart, I was able to over expose by 4.5 stops without clipping. I managed to grade the chart down to match the 2 x stops over exposed test with no quality loss.
I did find that with more overexposure the colours are more saturated, in slog3.
Here's a video I shot in slog3...
https://youtu.be/ikNr9KQT8fQ
    • Thank you Pieter! That's great input, I remember going to visiting stores before purchasing and you're right, it seemed most mirrorless cameras I had a look at seemed like great options overall. I decided to go with Sony for a few reasons, one of them being a good friend of mine in the product photography field has been using Sony only for ages. Another reason was the way Sony did indeed seem quite welcoming to 3rd party lenses, that is important to me. Appreciate your time and comment!
    • Yes. The display has its own settings and doesn’t necessarily show an accurate preview. You need to watch the exposure meter.
    • What is the issue? Live display doesn't accurately display actual output raw photo. It could be under or over-exposed. When focusing, sometimes you do get a glimpse of what your final image will be. (I believe this is because apparently on sony mirrorless, to aid the autofocus system, exposure is temporarely increased, this doesn't impact your actual exposure, its only temporary, therefore my theory is that what Im looking at, is my actual exposure + 1 stop maybe) The preview is shown as well-lit, however once you see the raw file it's way underexposed. After taking the picture, it somehow does increase the exposure and the output is more accurate to what is shown on live view, like if the camera took a screenshot or maybe the JPEG is wrongly labeled as .ARW, or somehow metada gets corrupted, since shows it was shot at the same settings, same ISO, same aperture, same exposure time but one picture is darker than the other. After taking the picture in this mode it loops back as taking the picture darker.
      Why I believe is an issue with the adapter? Changed the lens to the 50 mm f1.8 and same cycle repeats. Changed to the kit lens from sony and it work ok. Any help or theories? I know the simplest way would be, just use another adapter or maybe buy a sony lens but, I mean... there are plenty of people with this adapter, so could be an issue with this particular unit of adapter? I haven't seen something similar to my case on the internet.
