Does anyone know, of an adapter, that would let me use  a Leica 24 - 90 L mount, on a Sony A7 series  E mount ?
Google, in this case is not my friend ! Plenty of adapters for the Leica lenses  with other mount  types,
but I cannot find any mention of a Leica L mount lens, to a Sony E mount Camera ?
Any help would be greatly appreciated !
Cheers
Wally
I strongly suspect no-one makes one, and quite possibly never will.
Leica L has only 1-2mm more registration than e-mount which doesn't leave a lot of space for an adapter.
I've not got any L mount bits but I think it's also significantly wider than e-mount which almost certainly makes an adapter that focuses to infinity without optical elements impossible.
Google is showing you all the adapters there are ?
Edited by petrochemist
