This was actually more of an experiment. It is very rare to see clear skies in my area. I grabbed the closest camera and shot these photos handheld. I didn't have time to setup a tripod, etc. I found it interesting to see the same moon in daytime and nighttime.
Daytime Moon: Sony A6500, 70-350 mm lens at 350 mm, f/8, 1/2000 sec, ISO 800, handheld, file size reduced for web.
Nighttime Moon: Sony A6500, 70-350 mm lens at 350 mm, f/8, 1/1600 sec, ISO 6400, handheld, file size reduced for web.
John
  • 5 months later...
John
its very nice shot. In my country we can see the moon very often, and looks bigger as well but I don't know why exactly looks bigger in some areas and some no.
