Sony A7 III: Aperture dial not working
Is this a question or a notification?
Did you make sure the camera was in A(perture) or M(anual) mode? Make sure to set the lens aperture ring to A(utomatic) to make sure you can change the aperture from the camera.
  • 5 months later...
Hey all
just had the same issue and it’s a real easy fix. The click Aperture ring has a red ‘A’ after f/22. Turn it all the way so that this red ‘A’ aligns with the tick mark.
all works then. :)
Edited by SwissRob
  • 11 months later...
SwissRob - I had just bought the Sony Alpha 7riv along with Sigma Arts lenses.
This was driving me crazy - I could adjust the aperture only manually by rotating the ring... and was expecting the camera to do this on its own via a button. I didn't even think about an auto tick mark on it.
Damn this has saved me so much time !
Thank you !!!!
  • SAF Admin changed the title to Sony A7 III: Aperture dial not working
