Sony A7II announced!
SAR_admin
Additional mention with regard to the Sony "Profi" camera:
SR5: The A7II is not the “PRO” FE camera. The PRO FE camera is likely to be named A9 and will be announced and hit the stores the first half of 2015. And it has a new generation sensor!
. . . The weird thing is that SAR sources tell there is a second(!) new PRO model coming in January/February with:
– Advanced version of the A6000 hybrid AF system
– Weather sealed and mroe high quality body
– Sony will also NOT re-use the 36MP (A7r) or 24MP (A7 and A99) sensor.
(SR5) New PRO Full Frame A9 E-mount camera is placed above the A7 series.
One more thing about the new E-mount PRO FF camera coming in late January or early February. I have been told by trusted sources this camera will not be a A7/s/r replacement! It will be the first of a new line. The sources didn’t share the name of the camera but it’s highly likely this camera will be named “Sony A9“.
The camera will cost more than the current A7 models. I also have been told the Sony A7s will also see a first smaller price drop before the A9 announcement.
Specs of the A9 are not known yet but it has the fastest AF of any Sony mirrorless camera yet (more advanced than the one used by the A6000). Sony will also NOT re-use the 36MP (A7r) or 24MP (A7 and A99) sensor. Trusted sources told me the sensor is brand new."
based on that listing ,  that's £1000 or 1264 euro's.... I can live with that , but it won't let me pre-order :(
Careful with ordering cameras in Japan, they only include Japanese in the language selection, the price is tempting (especially when like me you live in europe) but if you are not fluent in Japanese, you won't be able to use it.
On the webpage, SAR states:
You can download the extensive A7m2 guide here on Wetransfer. And do not forget to preorder the camera here to get it before Christmas:
USA preorders:
Sony Alpha a7II  (Body Only) for $1,698 at Amazon (Click here), BHphoto (Click here), Adorama (Click here), SonyStore (Click here).
Sony Alpha a7II  with FE 28-70mm OSS Lens for $1,998 at Amazon (Click here), BHphoto (Click here), Adorama (Click here), SonyStore (Click here).
Sony 70-300mm f/4.5-5.6 G SSM II Lens for $1,148 at BHphoto (Click here).
I just clicked on the link from B&H and pre-ordered and contacted them but they said they don't have a shipping date yet :mellow:
Are we sure these will arrive before XMas?
was reading somewhere today December the 12th for usa? or is it pre order date?  noticed it is now available to pre-order in the UK too as of today.
    • Hello ! A friend gave me an old Sony SLT A65 that was locked in a suitcase for some years and guess what... It was pretty dirty. The translucent mirror looks strange. I know it's a pellicle mirror, but something is really weird , at least to me who never saw this entity before. It shows a rainbow pattern when lit, like a diffraction grid. And when I point the camera to a strong light source, let´s say streets lights or car lights, a huge halo and a diffuse pattern appears, almost like one of that photographic filters from the '70s. I guess the mirror is damaged. Does enyone have any experience with this ? I managed to remove the mirror and carefully rinse it with water and detergent solution , rinse again and dry, but the rainbow patter persists. My question is basically about the translucent mirror behavior with strong highlights and if the rainbow pattern on its surface is normal.   Thanks!
    • Sounds like you need a manual, and you are correct different settings can affect what you can do in the drive more.  Did you simple press the DRIVE button and select the THREE rectangles? There are several "burst" modes -- that you set with the Fn button or DRIVE button.  One takes several photos, when you press the button once (CONTINUOUS).  Another requires you to press the shutter button each time (SINGLE).  When you press the DRIVE button, what icon shows up -- a single rectangle or three?
    • If the 18-105 is too bulky, then so is the Tamron 17-70. Quality wise however, definately pick the Tamron over the Sony Zeiss 16-70, which is a compromised and dated design and similar in quality to the 18-105. I was in the same boat as you for a while (also had the 16-50 kit lens and 18-105 f/4), and went with the Sony 16-55 F/2.8 G. Happy with the choice as it's more compact than the Tamron 17-70 and vastly better quality than the Zony 16-70. In your case however, the omission of stabilized optics might be a dealbreaker. Did you consider the tiny but decent Sigma 18-50 f/2.8?
