Hi Everybody,
I'm about to get my new A7m2 and I'm researching lenses.
I want to get a super tele zoom (like the tamron 150-600) and the only options I see are third party.
Is there a difference between A-mount and EF or other mounts? since I will be using an adapter anyway?
I'm not planning on using the Sony made adapter as it's kind of large and expensive, I will probably get a Fotodiox adapter.
Thanks in advance,
Itay
If you are using A mount then it's best to get the Sony adapter. That way you will ensure as much compatibility as possible though you will still lose some functionality compared with FE lenses.
If you are happy to avoid the screw type lenses (generally earlier generation) and only use SAM or SSM lenses then Ea3 adaptor should be OK, otherwise you need the EA4.
I had the same choice to make for my A7Rii. I found this article to be very helpful, both in determining which lens/adapter combo to choose and also in explaining which features will and wont work with these combinations.
http://briansmith.com/best-150-600mm-superzoom-for-sony-a7rii/
As a result I bought the LA-EA3 adapter and the Tamron 150-600mm Sony A-mount lens.
My previous longest lens was the FE 70-200 f4 so having this Tamron lens opens up a lot of new possible shots for me.
The image quality with the Tamron is noticeably less good compared to any of my other lenses (Batis 25, FE 55mm, FE 90mm macro, FE 70-200mm) but it still can take great shots and I feel that it offers good value for money considering that it allows you to shoot at 500-600mm for a small fraction of the price of a 500mm or 600mm prime lens.
Hope that helps.
PS - Here is one picture taken with this lens at Helsinki Zoo last weekend https://500px.com/photo/129248493/great-grey-owl-by-andy-fowlie
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
