I have a Sony A7 camera, I have set the shoot mode to bracketing 5 frames at 0.7ev. The display viewfinder shows multiple triangular markings either side of mid point. All looks promising until I press the shutter release and the camera only takes one frame.
I also have a Sony A6000, with the exact same shoot mode settings it too shows multiple triangular markings either side of mid point. When I operate the shutter on the a6000 it rapidly takes 5 frames and when I view them each have a different exposure as expected.
Is there something different about the A7 or is there something I am missing?
Iit drove me mad over the weekend as I was shooting a catheral needed bracketing and ended up having to do it manually which is fraught even with a sturdy tripod.
Which bracketing mode are you using? Single bracketing or continuous bracketing? Single only takes one shot at a time and each shot within the bracket needs to be taken manually. In continuous bracketing mode, the shots in the bracket are taken automatically in quick succession.
  • 9 months later...
I just wanted to add a quick comment because this kept happening to me. I’m a full-time Commercial interior photographer I know what I’m doing I’ve read the manuals I was in the correct mode but camera was only shooting a single frame. Still not sure why it happened but it turned out it was an issue being caused by my flash. Once I disconnected and reconnected my flash the problem was rectified. Hope that helps anybody in the future👍
And it had nothing to do with the flash not regenerating quickly enough?
