Hello, I have had this camera for about a year (bought used). Works like a dream. I just looked up my shutter count and its at over 414000 shutter actuations. I believe is the original shutter. Is this a ticking time bomb? Anything I should do to help it last a while? Thoughts? Any of you around that with your 6300s? Also what does it cost to replace parts and labor?
Thanks!!
How many of the 414k shutter count are yours?  Depending on your answer you can consider whether you got a good deal or not.  I don't think there is anything you can do to extend the life of the camera, just shoot with it as long as you can.  Who knows, you might get another 414k shutter actuations out of the camera (touch wood).
Didn't you check the shutter count before buying the camera?  Even if your A6300 was a steal of a deal, I would not have bought this camera.  This is the condition guideline from a local camera store: https://kerrisdalecameras.com/used-equipment#item-condition-rating They are not rating a camera with near end of life shutter count - unfortunately your A6300 is well past it's expected shutter life.  Otoh, it's working without problems so I suggest you shoot with it as business as usual and hope for the best.
    • Problem Description – Sony ZV-E10 II A few weeks ago, I purchased my Sony ZV-E10 II camera from Digital Photo Supply. The unit is updated to the latest available firmware and is showing an abnormal behavior in the continuous autofocus system (AF-C), which can be consistently reproduced under different conditions and with various native Sony lenses. Observed Symptoms The parameters for focus transition speed (AF Transition Speed) and subject shift sensitivity (AF Subject Shift Sensitivity) do not remain stable. When the camera encounters a point or surface with low texture or contrast and takes time to focus, instead of maintaining smooth “focus breathing” according to the settings, it makes a sudden jump to focus. From that moment, autofocus behaves as if the speed were set to the highest value, completely ignoring the configured settings. After a few seconds, or when reframing, the system resumes normal operation. This phenomenon occurs even with Active Stabilization, Face/Eye AF, and Touch Tracking turned off. Testing Methodology Tests were conducted under various lighting conditions, both high-contrast and flat light. Different subjects were positioned at varying depth distances but laterally aligned (scenarios with partially overlapping elements). Medium and low focus transition speeds and medium or low subject sensitivity settings were used—these are the cinematic parameters I normally work with. All tests were performed exclusively with native Sony lenses, varying light and contrast levels to check behavioral consistency. Under these conditions, the camera consistently showed instances where, when using Spot Focus (S/M/L), it would momentarily lose focus and, upon regaining it, start focusing instantly on any new subject as the camera moved—completely ignoring the configured transition speeds. Control Camera Used A Sony ZV-E10 (Mark I) was used as a reference with identical lenses, settings, subjects, and lighting conditions. It passed all tests successfully without reproducing the issue. Impact on Professional Use This malfunction is catastrophic for my professional video work, where precise and fluid focus transitions are critical. When the system ignores transition speed and sensitivity settings, the footage becomes unusable, directly affecting visual continuity and cinematic quality. If this behavior cannot be corrected, the camera is unsuitable for professional video use, as it compromises focus system stability and predictability.
