Hello!
I’m new to Capture One 10 for Sony, and have a question about the Lens Correction tool (I’m coming over from Lightroom).
Capture One automatically selects my lens, and ticks/applies “chromatic aberration” and “hide distorted areas” with all else set to “0%”. Does this mean that although the profile for my lens was automatically selected and correcting for chromatic aberration, it has not applied correction to distortion, sharpness falloff or light fall off? To do so I would need to adjust these three to 100%? In fact they go up to 120%, whatever that means? The help file doesn’t answer that question.
Also, whilst I’m here, can I ask about sharpening and noise reduction. I’ve noticed the noise reduction slider for luminance, detail, and colour are always at 50. Is this an automatic correction and nothing else needs to be done? Same for sharpening, the amount is always 160, radius 1, threshold 1.
I’ve tried watching the tutorial videos and webinars and can’t find the answers to my questions.
Thanks.
Set the correction sliders to 100% for 100% correction, in each case. I think you can assign that to a preset. Behind that correction is a mathematical equation, which is why the correction can go beyond 100%, and perhaps there is a reason for that ... like you feel need a little bit more?
0% is no correction applied.
You have to adjust the sharpening to taste. Sometimes the defaults are OK, and sometimes not. Experiment a little to see the effect.
