SA2016 Posted May 12, 2016 Share Posted May 12, 2016 Please advise, I'm trying to find an L Bracket for the A7R mk2 which will allow for tethered capture when the camera is mounted on a tripod in portrait orientation (vertical) all ideas greatly appreciated. Link to post Share on other sites More sharing options...
Advertisement Posted May 12, 2016 Posted May 12, 2016 Hi SA2016, Take a look here L Bracket for Sony A7R mk2. I'm sure you'll find what you were looking for!
Guest Colin Scott Johnson Posted May 12, 2016 Share Posted May 12, 2016 Really Right Stuff Expensive, but the best. I just picked up plates for my new RX1r II and A6300 Link to post Share on other sites More sharing options...
rdgeorge55 Posted May 12, 2016 Share Posted May 12, 2016 Really Right Stuff! The only way to go. I have their L plate for my a7Rii and it allows vertical orientation with spacer for cable plug-ins. It does it in a very good way, with two retaining holes so that it is secure better than with friction alone. Two other great features: 1) The battery door gets moved to the plate itself. Very handy. 2) the Allen wrench stores on the plate itself. Also very handy. I also have the new L plate for my a6300. Very nice as well. The only way to go.... Link to post Share on other sites More sharing options...
adwb Posted May 12, 2016 Share Posted May 12, 2016 can you get that brand in the UK does any one know?? answer my own question, http://www.photospecialist.co.uk/really-right-stuff-ba7-l-set-l-plate-sony-a7-a7rbut at £205 I don't think so, sooner use the portrait position on my head ball heads. Link to post Share on other sites More sharing options...
Guest all8 Posted May 12, 2016 Share Posted May 12, 2016 RRS can be ordered direct from RRS, there is a European based reseller, but there is not much saving to be had (if any). The allen wrench storage is surprisingly useful, same goes for the similar setup with the Pano head. I can't use the L-plate in landscape orientation _with_ the Pano head _and_ a USB shutter release - the USB plug gets in the way of "the attachment mechanism" when the Lens is correctly aligned in the mount. But otherwise it should be possible, i.e. if not using a pano head or not aligning the lens correctly. However, for portrait orientation, the USB is accessible, and the HDMI should be too. Link to post Share on other sites More sharing options...
rdgeorge55 Posted May 13, 2016 Share Posted May 13, 2016 Some perspective: In the US the RRS L-plate costs $175 and provides arguably the absolute very best accessory for an a7Rii, which costs $3,200. It is worth every penny. Link to post Share on other sites More sharing options...
LostBoyNZ Posted May 13, 2016 Share Posted May 13, 2016 I third the RRS L-Plate for the A7r II, the one and only drawback I can think of is it makes it slightly harder to get at the ports of course, but that's unavoidable. It's really built extremely well, and I've tried a cheap eBay one myself. The one I kept was the RSS L-Plate Link to post Share on other sites More sharing options...
neilkking Posted May 13, 2016 Share Posted May 13, 2016 I think you should seriously look at the L bracket from Pro Media Gear for A7r2. Link to post Share on other sites More sharing options...
jeff Posted May 13, 2016 Share Posted May 13, 2016 I use the Desmond DAL-2 Modular L-Bracket it's only twenty bucks so I'm sure it's not up to the $175 variety. It's not the sturdiest thing so I have to watch bumps and vibration although I think that goes without saying when using a tripod in the first place. I have to move it away from the body depending upon what I'm connecting and have to connect or disconnect off the tripod. I also try and get 90˚ angle cables. Hope this helps on a side note: Geez Louise! how awesome is a $175 L bracket, sincerely? Kinda thought the whole point of these small mirrorless was not needing the grip required to hold up a medium format camera Link to post Share on other sites More sharing options...
