manual focus override in AF-c? 24-70/85 gmaster
it seems like I cannot manual focus while in AF mode...
do these lenses NOT have manual override???
i have to reprogram focus hold to toggle MF/AF which is an extra step.  many canon and nikon lenses allow manual focus override.
Use DMF mode. Thaz why it's there.
You wouldn't hafta reprogram to use
AF/MF toggle if you use AF/MF toggle
all the time ;-)
The Big Secret to getting the most
out of menu driven gear is just quit
wishin-n-bitchin and find out which
functions best serve your needs.
You can build your own cameras that
are exactly what you want. But the
only affordable way to do that is to
build tens of thousands of them. And
if you do that, you can't build them
to suit you personal idiosyncrasies
cuz you gotta get tens of thousands
of strangers to buy the other X9,997
cameras. Catch 22. Life sux. And very
clearly I lied in the first sentence of
this paragraph, just in hope that you'd
read the rest of it. I'm a Rat Fink !
focus override.
This part in particular:
"many canon and nikon lenses allow manual focus override."
Yes there is manual focus overide IN THE LENS ... usually
due to a non-mechanical link in the lens drive, such as an
ultrasonic drive, which uses vibrations-in-air as its drive
medium [ultrasonic drive].
But even the camera brands that offer such lenses require
that you use the buttons and menu choices to get practical
application of such things as sonic drive. Consider: You
really CAN manually refocus a sonic drive lens that is, at
the moment, in autofocus mode. Yes you can refocus it and
won't damage anything. But so what ? When you approve
that final focus tweak it's time to press the shutter button ...
and doing *that* will cause the lens to AF again, negating
your tweak. Acoarst that would be pointlessness. So you
go into the menus, buttons, and switches to disable the lens
from AF-ing away from your manual final focus tweak.
So .... there are no "canon and nikon lenses [that] allow
manual focus override." The lens alone can't simply, very
conveniently, all-by-itself, offer "manual focus override".
You hafta set up the camera, or at least keep a finger on
the AF-lock whilst using other fingers to manually tweak
the focus and then, while again nailing the AF-lock with
whatever finger, you use some other finger to release the
shutter. Common sense says to reconfig the camera rather
than do the finger-finger-finger thing.
