Crop factor FF -> APS-C is more like 1.53 so that would give 42.2 / 1.53² = 18.0 MP. A7Rii (same sensor as RX1Rii) also shoots 18.0 MP in crop mode.
That being said, I doubt the RX1Rii has a crop mode: this mode is primarily there to prevent vignetting in case someone puts an APS-C lens on a Fullframe camera. Since this camera has a fixed lens, this use case is irrelevant.
Thanks. I know the crop mode on FF cameras is to accommodate APS-c lenses.  I was just thinking (even at 18mp) that the crop mode would be handy, especially since it works in RAW, unlike Clear Image Zoom. I use the crop mode sometimes on my A7r cameras. Of course, I am not a camera engineer; one would think if the camera could do a crop mode in Raw, it could perform CIZ in Raw as well.
Ultimately, it is no different than cropping in post. Same result. Both are electronic zooms, if you will. The only advantage is you may be able to see a distant object better in crop mode, but in the end an image shot in Super 35 and one cropped to the same dimensions will be identical.
