Have you set the camera to connect to your cell phone? It probably won’t establish a connection automatically, it doesn’t in the a7.
I don’t know about the a7R ii, but I have just bought an a7 and after installing and setting Imaging Edge Mobile in my cell-phone as explained in the manual that came with my camera (that I could also download from the internet), each time I want to use my cell-phone with the camera I have to establish the connection via the “Menu” (as also explained in the manual).
I can perfectly view the images on my cell-phone and trigger the shutter from it (though just that with the a7). If it can be done with the a7, I would think it ought to work with the a7R ii (it is newer than the a7), but I don’t know.
Edited by Alejandro
Hamza,
I tried to check on my camera to see if I could add something to the subject, but now I can’t even connect via wi-fi. Everything was working fine, but a few days ago I accepted and did an update to Android 9 on my cell-phone. First thing that happened was that I got I sign saying that from now on, with Android 9, I ought to have the GPS on my cell-phone set to work to be able to establish a wi-fi connection with the camera. I did so (I switched on the GPS), but now, I am not being able to connect the camera to my cell-phone via wi-fi. I’ll keep trying and see if I can find out what and why I'm not being able to connect. In my case, Android (Android 9) is to blame (as everything was working fine before Android’s update).
Edited by Alejandro
Checked. In my case, the problem seems to be due to Android 9. I tried and tried and couldn’t establish the connection.
I have an old cell-phone which I keep because I use its GPS functions (I sail).
It has Andorid 6. I downloaded and have just installed Imaging Edge Mobile in that phone and it works fine, as it should. And I can see the object to be photographed both on the cell-phone and on the camera’s screen, and I can trigger the shutter (and the photo is sent to phone).
Edited by Alejandro
Problem solved (mine). I had to delete all references to the camera and the addresses of the wi-fi connection (or whatever is called) in my cell-phone (on the one recently updated to android 10, not android 9), and then allow the phone and Imaging Edge to recognize it again from zero. Now it works (differently though).
In the phone where I have Android 6, to establish the connection, I only need to set the camera to connect and to initiate the connection directly from and in Imaging Edge. In the phone where I have Android 10, I need to set the camera to connect, then go to Adjustments > Internet Connections in the phone and choose the name of the camera in the list of possible connections to wi-fi and activate it, and then initiate the connection from and in Imaging Edge. Maybe the difference is not due to Android different versions but because the phones are from different brands (?).
I forgot to tell you that I can also compensate exposure from the phone.
Anyway, obviously is not the same you are facing, as you can establish a connection but some functions are not working for you. Odd.
Edited by Alejandro
    • Yes if I do not get any concrete answers here that confirm either way I will have to resort to that.
    • You do know that Amazon offers generous free return service?  Just order any intervalometer that states compatibility with your camera model, try it out and if it doesn't work send it back and try a different brand.
    • Cengizt, what you want to get (and if you are usually mostly happy with the photos you directly shoot in jpg), might be better accomplished if you simply develop your raw files with Sony’s developing program: Imaging Edge Desktop (the one Sony allows to download from their website for free and can be used for the images taken with Sony cameras). Not bad and though very limited, it will allow you at least to recover shadows, a bit less of the highlights (not the burnt ones), correct white balance, and it will automatically correct lens distortions of most Sony lenses (not the ones from lenses of other brands in case you have any). With it, you can set the parameters for the take as you could have done it on camera (for example you can set the image to Vivid, as you asked for) or change the parameters as if you have done it on camera, but afterwards. As it has already been said, every other program does its own interpretation of the raw data of the image the better and more accurately they can. But Sony knows and uses (I might guess) their own developing algorithms (or whatever they are called), so you might be better off in respect to your goal just using the Sony program. After developing the file, you can export as tiff for further editing (and therefore keep on working with a 16 bit per channel image instead of an 8 bit per channel image as a jpg is).   But if you really want freedom and total versatility, using another good specific raw developing program, is obviously the better way to go. I don't use Lightroom, but from the ones I know and in my opinion, DxO PhotoLab excels for developing raw files (as has already been pointed out previously by Cameratose). It is expensive, but it is the champion concerning the automatic correction of the distortions of lenses and their chromatic aberrations, and one of the best if not the best for eliminating noise. It offers different good enough presets to choose from as a starting point, and you can make your own. Not complete enough for editing photos, though. ACDSee Ultimate is OK for developing raw and very good in my opinion for editing photos and with this one you can save your own parameters/presets to use as a start point as well (and it excels as a DAM for managing your media assets). Affinity Photo v1 or v2 (the previous ones to the very new and "freemium" Affinity by Canvas which I haven't nor will try) is/was limited for developing raw, it is good for editing images and very good in combination with Affinity Designer and Affinity Publisher for the tasks they can/could accomplish as a combo. Corel PaintShop Pro is very basic for developing raw and most of the correction for lenses it supposes to do are simply not done or done wrongly, though it is not bad but kind of outdated in my opinion for editing images. Capture One (which I tried when it had a limited free version for Sony cameras) is very good, but it has a limited list of lenses which distortions it corrects and is also very expensive. Concerning the rest of the programs, I don't have a clue nor can I recommend any, as I don´t have them nor have I tried any of them long enough.   Anyway, for what you wrote, you already have Lightroom and might want to stay with Adobe's program, which everybody says is excellent, though seems that most people (including me) hate their subscription scheme, and the monthly price which ought to be paid as long as being used (whilst there are programs for which you can only pay once if you want or update now and again, not necessarily every year).
