Sony a7SII - Live Stream
Hey,
I'm using an a7SII for live streaming through an HDMI capture device. I'm shooting a wide landscape, but the image is quite soft. Strangely, when you focus and the image digitally zooms it appears sharper than when not zoomed in.
Does the camera provide a lower quality preview through HDMI, but improves it temporarily for focusing? If this is true, then is there anyway to improve the preview quality?
Thanks
Is it only the PREVIEW quality that's bad or is the output quality bad as wall?
Use the same camera with external monitors/recorders and the signal DOES NOT degrade over HDMI. If you're relying on a digital (false, fake, phony) zoom to increase your reach then that's where your image will fall apart.
Thanks for your response.
I'm not recording, so it's just the live video feed going through HDMI into an external monitor.
My issue is that the digitally zoomed image (for focusing purposes) appears sharper than the standard wider shot when viewed over HDMI.
    • Hola, de un tamaño mas reducido que lo de aqui en España  Saludos Felipe  [url=https://flic.kr/p/2pQXGoV][img]https://live.staticflickr.com/65535/53718957065_012a904aaf_c.jpg[/img][/url][url=https://flic.kr/p/2pQXGoV]A7_08649nn[/url] by [url=https://www.flickr.com/photos/invierno123/]freme_3[/url], en Flickr
    • I have this lens and yes, it is normal if you shoot raw. Actually, what I discovered is that the lens is a little bit wider than 18 mm at the short end, and when shooting jpg, the image is slightly cropped, with still some residual distortion that I seldom correct, except for architectural pictures..  I totally agree with Pieter, the way lenses are designed has changed with the advent of digital cameras. In the old days of film, distortion, chromatic aberration and vignetting could not be corrected, especially when shooting slide film. This was not an issue with prime lenses, but was a major obstacle to zoom lenses development, up to the point tha magazines of the time warned against zoom lenses with more than 2-3X range.  Today lenses are designed as Pieter said, compromises are managed by software and this is even more evident in smartphones and compact cameras, which intentionally have no raw option.
    • For modern lens design, this is totally normal behaviour. To minimize size and weight of the lens and to improve many optical aspects, compromises are made in areas where the image can be corrected digitally. Distortion is one of these compromises: heavy barrel distortion is very common at the wide end of the focal range, up to a point where the corners of the sensor are not even covered by the projected image (i.e. rendered black). This is fixed by applying the proper distortion correction in your RAW editor: the black corners are stretched to a point beyond the image crop. Any leftover vignetting is then also digitally corrected. All this is done in-camera when processing a JPEG image, which is why it only shows up in RAW files. 2. Yes, these black corners are a property of the lens, not of the camera.
