It is really annoying that when I am video recording with continuous AF mode and I half press the shutter that my camera does refocus. Is there a way to turn this off???
In the stills menu you can turn off AF with shutter, but this doesn't work for video. I hope there is someone that can help me!
How about not pressing the button? There is a way to disable this in a 7Sii for better focus when you need it and the option should be available in a 7iii. The shutter button AF racks the focus in a jarring fashion. There's a way to smooth this whole process out.
Turn AF w/shutter to OFF. Then assign AF/MF to back button AF. This way a press of the button allows you to manually focus on a spot while shooting, move image reference to something else, then releasing the button AFs to the new subject matter. The new acquisition of the focus point ramps smoothly into play, instead of the rack in, rack out, in, out, panic stop, PING.
Edited by VTC
    • Could be a good travel lens I guess. I'd wait until there are some reliable reviews.
    • You have left it until the last minute. I don't know much about the a6000 but I'd be using Manual mode with Auto ISO. Is it Africa you are going on safari? If so, I imagine there will be plenty of light most of the time. You need to set a shutter speed to freeze any action. I would probably start with 1/1000 sec. and set aperture to just below maximum and let the ISO get the correct exposure. Take lots of shots and keep checking to see if you are getting the results you are after. Good luck.
    • This is just a quick and dirty first try composite from my efforts the other night attempting to capture the Full Lunar Eclipse. I will refine this and do a version with a foreground over the next week or so. The weather reports weren't good, as far as cloud cover went, so I was thinking I may not bother with it. The afternoon ended up being sunny and warmish with only the odd cloud here and there. I got my gear ready just in case. Sunset was just before 6:30 and after that I was checking the sky every half hour. Just around midnight I decided I would give it a go so I made some coffee and some sandwiches and headed off. So anyway, long story short, I had to brave the cold, the wind, a heavy dew, sea spray (the sea was quite rough and the tide was coming in fast) and quite a bit of cloud just after the full eclipse. Anyway, I'm pretty happy with this first attempt.
