A7R II settings Questions
Nowhr2run
I am entering recommended camera menu settings for the A7RII. I located a recommend setting for the camera from photograph life.com. I plan to initially set it to this website, but I will look for other recommended settings , compare and maybe change the settings.
As I was entering settings, the setting that were in the instructions stated that they could not be set and you had to be in , example RAW or some other Mode setting.
This brought me to my question.....Do you have to be in a SPECIFIC MODE when you enter the camera menu settings?
Ideal settings so far at least for me
Everything RAW ( or compressed  RAW ) To hell with JPEGS RAW All the way. However for clients who only respond to JPG I prefer to give them JPG only ( because that is how they think ).
ISO 100 ( note native is 800 ??? ) . Via night time shooting ISO 6400 is highest you can gain without loss. I have used higher ISO but it also affects the flash outcome alongside the shutte.
Shutter Speed 100-250. Why 250? Because I have yet to find any official SONY flash that is able to sync above that range. I have flashes that can go at 1/8000 per second but they slow down miserably
Aperture ( closed to get the starburst and focus infinity affect ) so I need tons of lighting. Only time I need the aperture open is if the scene is really dark, that being a fill flash can take care of that muddy mess in case I have to turn up the shutter speed.
If you are in a dark room the subject needs to stay still or the ISO needs to be raised, but again if you open that shutter you will gain Bokan ( blurred background ) however if your in a venue or club with a small space that will not matter. To compare to a sports arena where the lighting is optimal or even a concert/perfomance where it is questionable.
