yes I know but I noticed HEIF in 4:2:2 take about 1,5sec to open on my computer, when I can open 4:2:0 nearly in instant..maybe it does not look that much but when u have 1000 or 2000 files to watch and sort it's a difference.
4:2:0 has already a better quality than Jpeg and is lighter too, not sure I need extra color info of the 4:2:2 for postprocessing, except maybe in rare case. Maybe I'll mix both depending on the situation.
Anyway thanks for your infos
Do you notice it for every photo you take? I don't think it's the sensor since it's not in the same place. I had something similar when my SD was failing. Maybe check with another card.
I think color profile in LR is at fault here. I think for JPEG it uses sRGB and sRGB is 8bits afaik, HEIC is rendered using Display P3 so somehow that gradient is smoother because 8bits are displayed on a 10bit profile?
Why don't you just use 4:2:2 and that's it? It's better to have more information from which you can "remove" later in post than not having enough.
