A6300 built in flash issue
Hi all,
Since two days I have an issue with the built in flash of my A6300.  I don't use it much, but every now and then I do. What happens is that the flash does not fire and that in the viewfinder, I have the Icon for a flash with an orange dot which mean "Flash charge in progress". I can understand this for an external flash,  but not for the internal. For the record, I have tried many things and with an external flash it works, although sometimes (also recently) I have to fit the flas one or two times on the hot shoe before it connects..
Ad yes, silent shooting and so are all off and the problem exists in all flash modes. Any ideas anyone?
Thanks
Ubo
Any flash needs time to charge. Time required depends on the particular flash design and, of course, battery charge available.
Why the flash does not fire is another issue, and may have various causes, a defective flash being one of them.
Do you say that the "Flash charge in progress" indicator light remains on, indicating that the flash does not charge? If true, with a fully charged battery, then your camera needs to be repaired.
