Hello. I remembered that I had film photography equipment inherited from grandfather who was photographer many lens and other photography/filming equipment. Among them most interesting was Jupiter-9 f/2.0 contax type mount lens which I want to use with Sony A3000 camera.
Are there adapters to attach lens to Sony E. mount type camera? As well since I have APS-C camera maybe you can also recommend right speed booster lens and autofocus adapter? I seen there are many autofocus adapters including speed booster lens but problem is that adding multiple adapters can increase lens distance from sensor so much image might be out of focus. I also consider making own adapter and I could use even lens for speed boosting that I have. Anybody tried this?
Jupiter-9 bayonet
I assume it's not a Contax bayonet, but a Contarex, like this one I found on Ebay.
I'm not sure it's worth it, it's pretty expensive. An adapter for the widespread M39 screw mount version of the Jupiter 9 would be far cheaper. Many other Soviet lenses came in M39 or M42, sometimes even with an adapter ring between the two.
Edited by nomad
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
