E Mount Cameras Only?
Howie
I follow the SAR site and following your prompting on there Andrea I joined this forum; however it looks to me as if this is for E mount camera owners only? If that's the case there's little point me being here LOL (I'm an A200 and A580 owner).
Howie
Same here. I thought it was about Sony E-mount system cameras. I have no clue about A-mount or Sony SLT/DSLRs and I am not sure if it would make sense to have these systems all mixed in one forum. At least it might be good to have a clear separation between A-mount system cameras and E-mount system cameras.. For me, it does get confusing when eg talking about the new Sony lenses, as there seem to be equivalent editions for both A- and E-mount (FE)..
