Sony A7 II lost display in EVF and also on rear screen by my mistake.......
I have lost display in the viewfinder and also on the rear screen of my A7 ii, which I have recently bought second hand. The camera takes photos, but I don't see what I am taking photos of, these get recorded on the SD Card.
Can someone help to recover my mistake? May be a reset might help, but I do not know where to start?
Thanks very much in advance
Amar
Option to turn on and off the VF and rear LCD screen is in the Menu.
I do not have the camera with me right now to check and guide you exactly how to reach it, but I do recall these options exist. Just scroll through the lot, take maybe 5-10 min to find it.
The best!
