Sony a9 ii screen lcd monitor yellow problem
tdi
i got second hand a9ii and there is problem on screen. right side is dimmer or yellow. what causes this?
any solution? or part number for the screen?
I think it is caused by breathing steam when you use viewfinder. Seems that peoples have this problem mostly left side of the screen because 70% use right eye and nose is on left side. In my case nose has been on the right side of the screen and got some water damage. Otherwise camera works perfect, so in some point im going to replace that screen. Can some one give me part number for that? i found that it might use same screen than a7r4? but not 100% sure.
