Sony A7iii display shows color shades during focusing!! Please someone help!
So I recently bought a sony A7iii and got a 50mm 1.8 lens and started using it! Whenever i focus there is this shades of blue and orange color in the display for about the time it takes to focus and its strong on the pictures!! Sometimes even after focusing a little bit!! Because of this i cant take photos unless i focus on an object and wait 3-5 sec and click the shutter!! Does someone know anything related to this? I have attached a picture to this thread that is what's happening!!
Maybe that's why they sold it.  Do you have an owner's manual?  If not, get one on-line.  Then reset ALL settings to the factory default.  Then restart it with a fully-charged battery.  I doubt that will solve the problem, but if not, return it.
Edited by XKAES
@Shemeesh
How does the images look if you take the SD card and view the images on a PC/Laptop/Mac?  If the image are fine on them then it's the LCD screen on your camera that's faulty.  If the camera was bought used via private sale and can't be returned then your option is to have the LCD screen replaced at your cost (check YT for reference) or live with the faulty screen.  It would be real annoying if you happen to chimp a lot but may not be unbearable to you.
