a58 images saved vertical when shooting horizontal
My a58 is saving images vertical when I keep the camera in horizontal position. When I keep the camera up side down the images are saved correctly. I have done a reset but no result. I also connected the camera to my laptop and used the remote software, same problem. Broken position sensor?
Update: Could solve it by putting the camera in panorama mode. The camera makes several frames and stiches the frames to one panorama. I could hear the camera clicking a lot of times when it was making the images. I guess by doing this the position sensor got loose or calibrated itself, I have no idea how this sensor works but it did the trick. The camera is working normal again.
