Hi
On my A6000 I was able to zoom into the photos in playback mode just with the wheel. On the A7rIII, I now need to press a stupid button before I can zoom. Is there a way to change this? I mean there are 3 dials, and all seem to do the exact same thing (scrolling through the images).
Hi
Check the custom button settings in playback mode.
