So I've just got the A6500 from Sony for making video. The 18-105 f4 has been perfect for all my filming so far but with winter coming I need to get some faster glass to get some more light in on these dark nights. Have some questions...
If you put the Sony 35mm 1.8 with stabilisation on the A6500 with stabilisation do both stabilisers work or does one switch off the other?
Is the f1.4 from sigma in real-world terms going to let much extra light in compared to the Sony f1.8?
Does AF on the sigma work as good as on the Sony?
Is the A6500 stabilsation enough if I went with the Sigma?
Many thanks everyone,
G
Given your uses and your concerns, the difference
between f/1.8 and f/1.4 pales compared to choosing
between Sony and Sigma firmware. As example, it
seems you want maximum benefit of OSS and IBIS
working in tandem. Don't collect opinions based on
multiple users' relatively narrow scopes of empirical
evidence. Crowd sourced advice has a verrrry scary
track record. Stay with an all-OEM rig, engineered
with benefit of knowledge aforethought.
Just for example:
All may seem perficklee OK initially. Then comes a
necessity to update the firmware in the 6500 [many
possible scenarios]. Thaz when you might come to
deeply regret Sigma's approach to firmware.
Sony E 35mm f1.8 is the only APS-C lens with full support for the hybrid autofocus found in A6x00 cameras. Sigma lenses on the other hand, have very reduced hybrid af performance. That is important as hybrid af is the main selling point of Sony mirrorless cameras.
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
