Hello together,
I bought my A6500 3 weeks ago. I was on vacation with it, so i already have taken 4k photos with it.
And overall, i like the camera, especial the large number of setting options.
But i have a problem with taking photos from flowers. Especially pink and purple coloured flowers came out a lot to red on the photo.
I never saw this effect before, when i was taking pictures with my mobile phone. So i decided to do an comparison.
And this confirmed this problem. The mobile phone camera does not always match the color perfectly, but it is definitely much better than the A6500.
I also tried to do a manual white balance. But even the most extreme setting didn't come close to producing the right colour. But all the other colors were wrong.
Here are a few sample images:
My Camera:
- Sony Alpha 6500 (firmware 1.04.)
- Sony Emount E PZ 18-105mm F4 G OSS (Firmware v04)
A1: mobile phone: nearly perfect colour
A2: A6500: much to red
A3: A6500: manual white balance - absolutly impossible to tweak the colour in the right way, background getting much to blue
A4: A6500: shot an picture from the display of my mobile. The colour looks good.
Because it isn't possible to tweak the white balace in the right way, and there is no isse with the pink colour, when taking a picture from the phones display, i decided, that it's not an issue withe the white balace at all. I took some more pictures:
And some other examples:
B1: mobile phone: perfect colour
B2: A6500: much to red
C1: mobile phone: good colour
C2: A6500: Even this is a very similar colour, in this case, ther is no problem, the coloures are right?!
D1: mobile phone: good coloures
D2: A6500: the pink markers are much to red
E1: mobile phone: colour is OK
E2: A6500: again much to red
Then i thought about ultra violet light. Perhapps the objective is filtering it to much? I looked through it with my eyes, but the colours of the flower were correct.
So perhapps, there is an UV-filter on top of the sensor.
So i did some comparisons with an UV-Laser and green laser:
F: green and ultraviolet laser beam
F1: mobile phone: looks like i see it
F2: A6500: UV-Laser appears to dark
G: unfocused UV-Laser beam and white LED flashlight
G1: mobile phone: to blue, but brightness comparison is correct
G2: A6500: the UV-laser disappears totally
H1: mobile phone: colours are good
H2: A6500: pink markers are much to red
I1: mobile phone: looks a bit to bluish
I2: A6500: Colour looks better then on the phone, but it's to dark
J1: mobile phone: Colours are good
J2: A6500: again much to red
K1: mobile phone: colour looks OK
K2: A6500: again much to red.
So, is it an UV-filter problem? Is the filter to strong.
Or am I wrong, and there's another reason?
Has anyone else made similar observations with the A6500.
Or is something wrong with my camera. Or is it even a normal thing with some cameras?
Is there a workaround?
Thank you for your help
Jörg
Would shoot in RAW and process in software of your choice on computer
such as Lightroom. Would avoid JPEG straight from camera.
Sent from my iPad using Tapatalk Pro
That advice would assume the jpeg engine is running red, which
is unlikely ... but "unlikely" is no reason not to try it anyway. But I
suspect it's a combination of saturation setting and WB setting.
Saturation can be adjusted in the effect editor. WB should be
adjusted in the dual axis A-B/M-G chart, and by the wording of
the opening post, I suspect that "manual white balance" does
NOT mean adjustment what done at the base level on the dual
axis chart. On the chart, I estimate a minus 5 A [amber] and a
minus 3 M [magenta] would be a good starting point to try.
Hey together,
thank You for your reply.
Year, i forgot to try RAW. I will do that on weekend. But i don't expect any diferences.
And it also looks wrong at the finder/display before shot.
But I  suspect it's a combination of saturation setting and WB setting.
Thank You for Your good explanation.
But, if i get You right, than this can not be the reason, because:
- i shot in P-Mode
- i do not use the creative style, or Picture Effect, or Picture Profile
- i tried to adjust WB in Picture A3. And Yes, i mean in the settings
         Photo1/Page11/White Balance/Custom 1
         There is an Colour-Field, i think, thats what You mean, but i tried every possible setting (Picture A3 is : B(lue?) to 7 and M(agenta) to 7--> maximum
         And it's easy to see at the background in Picture A3, that the WB is terrible, but the flower is not even close to look right.
I'm pretty sure it has nothing to do with white balance, firstly because the colour difference is so extreme, and secondly so specific only for one colour.
But I don't wan't to stop you. Please give me some more ideas. Does not anyone have similar issues, i mean, it's very noticeable.
Thank You again,
Jörg
Quick answer. Camera white balance gets flowers wrong 95% of the time. Normal methods for equalising grey in post processing only works 30% of the time on flowers.
So, if you want accurate reproduction of flower colours, the only option is a colour chart. I use X-Rite colorchecker passport. It's a fast and effective way of controlling colours.
PS: mobile phones don't have more accurate colours. They're just programmed to look more appealing without processing. A camera is built on the idea that you will do your own processing.
- i shot in P-Mode
tried every possible setting ...............
As Jaf has mentioned, flowers can defy the imaging system,
so you may hafta select areas to edit independently for WB
adjustment.
As for your "P-mode" comment, how you meter and how you
juggle aperture vs shutter speed is toadally unrelated. Thaz
all P,A, and S modes do ... exposure metering and juggle the
speed vs aperture.
As to creative style, do NOT say your not using one. Check
your image data and you'll find your ALWAYS using one. So
make sure you're using Neutral, Faithful, or Standard, then
open up the "options" for it where you can reduce saturation.
It's good that you use the 2-axis "Color Field" ... but possibly
pushing magenta to "7" might be the opposite of a fix. The
"Color Field" is a global adjustment. The everything else is
affected and the adjustment remains until you go back and
re-do the 2-axis settings.
Hello together,
thanks again for your replies.
I made some tests, and now it's looking better.
But first i wan't to answer Your questions:
When outside in normal daylight, did you try Daylight WB as a starting point ?
When taking pics of flowers, i often need to go to that setting to get more realistic colours
Yes, of course, that was the first i tried. I also tried to do an manual WB like "Username" asked me. The issue was, like you see in the background, the WB is not that bad. And when i tried to do a manual WB, i could not get even close to the right colour of the flower, but lost my correct white balance in the background.
That's true, i'm sory not to be clear in this point.
I just wanted to make the explanation short.
I'm using the standard effect.
Like i said, i tried all possible points on the 2-axis colour field live in front of the flower, but i was not getting even close.
Now, what i tried:
- I saved pictures not only in Jpeg, but also in ARW (Sony RAW)
- I experimented with Creative Style and Picture Profile. And i was overwhelmed by the amount of settings you have with the Picture Profile.
Here are the results:
Left Pictures: converted ARW with Adobe DNG Converter and viewed in Adobe Photoshop
Middle Pictures: Viewed ARW with Windows 10 Microsoft.Photos.exe after installing Sony RAW Driver - I think it's just a thumbnail of the JPEG file, what we can see here, because the colours always looks similar, but the resolution is bad.
Right Pictures: Viewed Jpeg with Windows 10 Microsoft.Photos.exe.
All pictures are just screenshots and later compressed JPEG-Files, because i can't upload more than 1MB. But i always checked the colours, and nothing changed.
What I saw in the finder: Background: green a litel to less green, blue, a lite to blue
Pink marker: to red
Quality:        RAW & JPEG
Color Space:        sRGB (AdobeRGB makes no visible difference)
Exposure Comp.        +-0.0
White Balance        Auto
DRO/AUTO HDR        Off
Creative Style        Standard
Picture Effect        Off
Picture Profile        Off
Soft Skin Effect    Off
What I saw in the finder: Background: green a litel to much green, blue, a lite to blue
Pink marker: to red, but better
Quality:        RAW & JPEG
White Balance        Auto
DRO/AUTO HDR        Off
Creative Style        Vivid
Picture Effect        Off
Picture Profile        Off
What I saw in the finder: Background: green good, blue, a lite to blue, but better
Pink marker: to red, but even better
Quality:        RAW & JPEG
White Balance        Auto
DRO/AUTO HDR        Off
Picture Effect        Off
Picture Profile        PP1 (with no changes)
What I saw in the finder: Background: green very good, blue (now turquise), perfect
Pink marker: nearly perfect
Quality:        RAW & JPEG
White Balance        Auto
DRO/AUTO HDR        Off
Picture Effect        Off
Picture Profile        PP1:
                Color Mode: From Movie to ITU709 Matrix
                Color Phase: +2
So, if you look at the right picture of the last series, this is matching very good, what it really looks like.
I'm very happy to have found the possibilities of Picture Profile, thank You "Username" to point me on this.
But i already determined, that this last setting is not the solution for every case. With other light ect. it does not look correct.
But because i have a number of programable Picture Modes, i can adjust a few, so that hopefully i have one for each situation. Picture Mode is already liked to my first custom button :-).
By the way, the most important change, to get the colour right, was the Color Phase option.
Now, there is just one more issue: The colours in the finder do not match perfectly to the display colours, and viewing it on my laptop gives me even another colour.
So, how do I calibrate my colours now. The world is not perfect :D
Greetings
Jörg
    • This is a discussion forum, it's not Sony. You should send your request to their customer service department.
    • Sorry, had to catch your attention somehow.  🙂 I've loved Zeiss lenses for a couple decades--have been a fotog since only 2000--and have had many different versions.. Bought an a7R V weeks ago, attached the Batis 18/2.8, added an 85/2.8 plus a Sony 24-70/2.8 GM II and a Tamrom 50-300 4.5-6.3, and thought I was ready.. But then ordered Batises in 25/2 and 40/2 (arriving today), and then ordered a 135/2.8 to arrive ...tomorrow, Thursday?  (How can B&H/FedEx do that--Wed. morn. to Thurs. afternoon--for the few-dollars addon B&H gets for NEXT-day shipping?)  Total gear weight without the Tamron will be just 6.8 pounds/3.7kg and 8.4 pounds/3.8kg. with it.. All this (and other required stuff) fits in my ThinkTank Airport Roller, so I won't have to carry it, which I cannot physically do. Off to two and two-half days in the Palouse Monday the 2nd; we'll see how all those Bs hold up.
    • Hello, Would it be possible in a future firmware update for DSLRs to change the order of White Balance options in the menu?   It would be much more practical if the Kelvin (K) setting was listed first, followed by Auto, and then the rest of the predefined options.   When filming, it would allow for a quicker switch from Auto to Kelvin mode and then easily adjust the exact white balance using the DIAL wheel – and quickly return to Auto if needed.   Currently, we need to scroll through several predefined white balance presets to switch between Auto and a custom Kelvin setting, which can be impractical during a shoot.
