I took these a few nights ago while the oceans were calm. Shot with an a6000 and the FE 70-200mm F4 G OSS. The OSS on the lens works really well. These were all hand held and zoomed in at 200mm.
  • 2 months later...
The moon the other night.
Another amazing sunset.
