Voigtlander 10mm f5.6 - my first shots
Those pix show that the only function for the outermost
areas within the frame is to emphasize, or complement,
the more significant and more central main area.
IOW you can't actually use the entire frame to picture a
wide view. You can use the area corresponding to the
approximate view of a 14 or 16mm lens and fill it with
whatever falls into that somewhat lesser angle of view,
and the only benefit offered by shooting it with a 10mm
is that you get to surround your 15mm view with these
"extensions" of the content seen in the 15mm view. No
useful extra content is included by the 10mm.
This is essentially a pictorial effect, an interesting way
of insulating the "15mm content" from direct contact
with the "harsh reality" of the four straight lines known
as "The Edges of the Picture". And it's an effect I love !
I used to use a handheld 4x5 equipt with a 47mm lens.
It was a personal "photo toy", which had no commercial
application. This was more like a 12mm, so not as crazy
as a 10mm [10, 12, 15mm all referring to 24x36 sensor]
but the effect was the same. It looked like a 3x4 picture
is set into a 4x5 space and then the content of the outer
regions of that 3x4 picture get elastically stretched out to
populate the extra real estate in between the 3x4 image
and the margins of the actual 4x5 piece of film.
It's cool. I love how it just about eliminates any need to
to fuss over how your subject's details interact with the
format's sharp edges which harshly declare " You can't
see nuthin' past these arbitrary straight lines out here ! "
It feathers the boundaries of the area of interest, rather
than cutting it off abruptly. There's no impact of subject
matter in collision with the rectangle that's walling it in.
It's as if the picture is "self matting" and the matt is not
some bald, blank-looking neutral surround. Rather, this
"matt" complements the content within it's boundaries,
cuz this matt is colored by shapes and colors bled out
onto it, spreading from the picture within its boundaries.
The image generates its own buffer zone between the
subject area and the rest of the world outside it.
For a flat sensor [or film], rectilinear lenses shorter than
40% of the width of the format don't actually encompass
much extra subject field. They mainly just do the stretch
thing described above. Acoarst the 40% limit refers only
to "reasonable" rectangles. If the format is an elongated
panorama-like strip then it's a somewhat different game :-)
It's a very useful effect, but don't be fooled into thinking
that a 10mm encompasses 50% more subject than a 15.
That would be true for 10 vs 15mm on ASP-C but not on
the 24x36mm [FF] format. On APS-C 10mm hits the 40%
limit, but doesn't go beyond.
Acoarst, there hasta be a touch of wiggle room allowed
concerning the numbers used above, but not very much !
PP would do a lot of good. ;-)
I'd love to see your shots after you've tweaked them a bit.
On a side note, I became completely enamored with the ultra wide look after picking up a Laowa 15mm (the angle was great, the files were sh#t due to a complete lack of sharpness at any setting) and actually stopped by B&H during my last trip to NYC to try out the Voigtlanders.  As none were available, I ended up buy the 85 GM......not the least bit unhappy with that purchase.  That being said, I'd love to see more of your work to see what the 10mm is capable of.
    • For modern lens design, this is totally normal behaviour. To minimize size and weight of the lens and to improve many optical aspects, compromises are made in areas where the image can be corrected digitally. Distortion is one of these compromises: heavy barrel distortion is very common at the wide end of the focal range, up to a point where the corners of the sensor are not even covered by the projected image (i.e. rendered black). This is fixed by applying the proper distortion correction in your RAW editor: the black corners are stretched to a point beyond the image crop. Any leftover vignetting is then also digitally corrected. All this is done in-camera when processing a JPEG image, which is why it only shows up in RAW files. 2. Yes, these black corners are a property of the lens, not of the camera.
    • Hi Guys, I was shooting some flowers today. when I checked the images back home, I found out that all images in RAW format with 18mm focal length had heavy image distortion and were black-cornered. I wonder if this is the same case for you guys? If so,  is this issue solvable? if so, how did you guys solve it? 2. can I still use any focal length that's larger than 18mm( ex. 16mm) on this camera body?     Note: Len is Sony's 18-135mm OSS only images that had a focal length of 18mm had this problem only in RAW format. the same image in Jpeg did not get affected   Here are some sample images for your reference: https://drive.google.com/file/d/10-I9wUBPo9KT-aaW7Fhtx2v9WCnJ3vbT/view?usp=sharing https://drive.google.com/file/d/10-I9wUBPo9KT-aaW7Fhtx2v9WCnJ3vbT/view?usp=sharing
    • Check the contents of this forum, that subject has been covered many times.  If you are looking for adapters with best AF functionality, Sony's own offerings is probably your best choice.
