Hello,
Would it be possible in a future firmware update for DSLRs to change the order of White Balance options in the menu?
It would be much more practical if the Kelvin (K) setting was listed first, followed by Auto, and then the rest of the predefined options.
When filming, it would allow for a quicker switch from Auto to Kelvin mode and then easily adjust the exact white balance using the DIAL wheel – and quickly return to Auto if needed.
Currently, we need to scroll through several predefined white balance presets to switch between Auto and a custom Kelvin setting, which can be impractical during a shoot.
  • Olaf W. changed the title to Sony A7IV - White Balance menu
21 hours ago, Cameratose said:
Seems you could also program it to a custom button.
It can be assigned to a custom button for quick white balance selection, but then the order becomes important. It starts with AWB, then goes through several presets, and only in the middle is the Kelvin setting, where you can adjust it with the dial.
If you’re making this change during recording, the process of switching through options gets recorded as well.
If the Kelvin option came first, followed by Auto, it would be much quicker and less noticeable to switch during filming.
22 hours ago, VTC said:
On my camera CWB is at bottom of list so to shorten the travel time I travel UP instead of down. That way I'm ONE SCROLL to destination instead of 6 or 7.
Yes, but then the precise Kelvin setting should be at the end — and currently, it’s placed above a few CWB options.
On 5/28/2025 at 11:17 PM, Cameratose said:
This is a discussion forum, it's not Sony. You should send your request to their customer service department.
Which email or website is best for giving feedback about Sony DSLR cameras?
I'd have to look it up, same as you. I'm afraid you'll have to do your own homework on that.
    • Thanks. Both dials front and rear do not work and the camera is now in the repair shop.
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
