Hello all.
I'm new to the Sony gene pool.
I recently picked up an A7CR with the Sony 90mm OSS Macro lens.
I find that I can't get IBS or lens stabilization to work when I switch the lens to Manual Focus mode using the sliding bayonet switch on the lens.
I use the AF ON backbitten focus, and I get an error message when I activate the button in MF.   The error message makes sense, but in other camera platforms, the IS still works.
Is there any way to have the IS still work while the lens is in manual focus mode?   I've searched and searched and can't find a way to make it work.
Thanks
Is the 'optical steady shot' switch on the side of the lens set to 'ON'?
Stabilization should still work even with the lens set to manual focus, but to be honest I'm not sure if it only kicks in right before taking the shot, or also while composing. In AF-mode, stabilization only works while focussing (I guess to save battery power).
Thanks.
Yep, OSS is on.  Stabilization works as expected using Autofocus (impressively so)
My old Nikon would continue the IS if the AF On was pressed, even when the lens was set to MF.
I tried a half press of the shutter button, but it seems that the IS is directly coupled to the Focus function.  No focus function, no IS.   I was expecting the IBS to work even if the lens OSS didn't.
It's not a deal breaker, but some IS would be handy when shooting macro hand held in MF.
Upon further testing, it seems that the Stabilization does engage in manual focus when the shutter button is partially depressed.
I'd prefer to use the AF On button, but I'll just need to relearn how to use the Focus button.
    • Hi. tried this one. I have the same problem and read your post. I tried everything until this. it worked.   LuckySn0wMan •4mo ago•Edited 4mo ago   I've just had exactly this issue recently on my Sony A7r2 and successfully resolved it. I bought this camera used, so looks like the previous owner of the camera tweaked it's firmware to unlock additional languages. These tweaks caused this issue after the camera spent significant amount of time without the battery installed. Note that on ny camera the OpenMemories tweak app is not installed, so I used the pmca-gui PC application to change tweak settings of the camera firmware without the OpenMemories in camera app. So my sequence of actions to fix the camera: Install the battery. Connect the camera via micro-usb cable to your windows bases PC. Power on the camera. It should start in mass storage mode. Download the pmca-gui-v0.18-win.exe executable from the official github page: https://github.com/ma1co/Sony-PMCA-RE/releases. On the Camera info tab press the Get camera info button just to test that the app can successfully detect the camera. Go to the Tweaks tab. Press the Start tweaking (updater mode) button. The Updater mode tweaks tab should popup. Camera display will be completely black and the buttom right LED will be on. Select the Unlock protected setting checkbox. Uncheck the Unlock all languages checkbox. Uncheck the Unlock protected setting checkbox. Press the Done button. Once the app applies all changes to the camera firmware, exit from the app and power off the camera. After power on the camera should start working as usual. As additional info: My camera had the following tweak settings during the gray screen problem: Disable video recording limit: not selected Unlock all languages: selected (possible cause of the bug) Enable PAL/NTSC selector & warning: selected Enable USB app installer: not selected Unlock protected settings: selected After my changes that helped to fix the camera power on gray screen: Not selected Not selected Selected Not selected Not selected
