Hello,
Seeking advice. The AP mode will not change the aperture. The dial is working fine. I have checked all settings and even did a factory reset. When I switch the dial to AP, the shutter speed change, the F stop remains fixed at 20. The ISO remains the same. The compensation +/- changes. Any ideas what is going wrong?
You can control which dial is used for which parameter. In M it defaults to a particular assignment of aperture and shutter (I think Aperture is front dial). In A I think the default is both dials control aperture (again, you can change this).
There have been times when I have thought a dial wasn’t working, but the answer was that I already had the lens wide open, so any attempt to open it further was ignored (I think the camera was screaming at me “go buy another lens if you want it wider than this!”). In my defence, I had forgotten that I had the 1.4x attached, and that makes it hard to open up wider than f/4 on the 70-200 f/2.8!
My strong recommendation is: when the dial appears not to be working, try turning it the opposite direction - this will tell you immediately if you’d reached the limit. It also lets you know if you’d switched the direction of the dials (yet another thing you can change).
Thank you for all of the advice. The dial is definitely set to A. If I move the wheel left or right the aperture remains fixed at f22. I have tried changing the iso and no change with aperture for either lens. The aperture does change in manual mode. It is frustrating me. I wonder if there is a setting in the menu that is blocking this?
You are not going to believe what the issue is and it’s an easy fix. If the lens is not on A, Aperture priority on the camera will not work. I have now locked the aperture on the lens.
Has anyone else had this issue?
Yes, if aperture is set on the lens, that's the aperture that's being used. You can't override it with the aperture dial on the camera.
9 hours ago, Olaf W. said:
Neither did I. It‘s quite a curious implementation of aperture mode where you can’t set the aperture at the lens…
I disagree.
If the LENS is not on A, then the aperture ring on the lens controls the aperture. That's how aperture rings are expected to work - Nikkor lenses work that way, too. I would expect the aperture ring to work like that. Aperture priority still works, but the aperture is set on the lens, not using a dial on the camera. Maybe I find this easier to understand after using a Voigtlander lens, where the aperture ring is the ONLY way to set the aperture - they work beautifully in A mode, as long as you set the aperture using the aperture ring on the lens.
Once you put the aperture ring on the lens on A, then the aperture can be controlled (except on a Voigtlander!)  by a dial on the camera in M or A modes. In green rectangle, P, and S modes you don't control the aperture.
The OP was asked by Snoflu on 22 November if the aperture ring was set to A...
Also, we might want to clarify that the OP understands what is meant by "both dials" - there are two dials at the back of the camera - the left one is plain black, and is the "rear dial"; the right one is the Exposure Compensation dial by default (but can be customised). There is a third dial at the front of the grip below the shutter button - that is the "front dial". When someone asks if you have tried moving "both dials" they usually mean the "front" and "rear" dials (the left rear dial, not the right rear dial).
Guest
This topic is now closed to further replies.
