Sony A1 freezing
Pippin
I have tried a few different lenses on my Sony A1 - original and well used - and every now and again it freezes - and doesn't show an f number. The only way to get around this is to shut it down take the lens off and then put it back on and start up again.
I am due to go to Kenya next month and don't want this to happen just at the wrong moment.
Any suggestions ?
I thought about sending it to get repaired but the shop sends it to London and they don't know the turnaround time.
Could you define "every now and again"?
Does "freezes" mean it fails to show the f-stop (somewhere), but otherwise works OK?
Or does "freezes" mean "nothing works" and, by the way, it fails to show the f-stop?
We are not looking over your shoulder.
Are all of your lenses made-by-Sony e-mount lenses?
Edited by XKAES
Once or twice at month it freezes it fails to show the f stop but nothing works and I have to turn it off and on again and then it works fine  I just don't want this to happen whilst photographing wildlife in Kent in a couple of weeks. All of my lenses are Sony E mount lenses, this has happened with all three lenses 24-70,200-600 and 70-200 lenses.
Thanks.  That seem to point to the camera as the problem, but since it happens so infrequently, nailing down a solution will be difficult.  Here's what I'd try:
#1: Reset everything in the menus to the factory default
#2: Only use SONY batteries
#3: Make sure you have the latest FIRMWARE for the A1
#4: Reset the menu items to your preferences.
#5: Cross your fingers
  • 4 weeks later...
Good point.  The final Sony a-mount camera (a99II?) was last manufactured in, I would guess, about four years ago.
So if you like a-mount cameras, better get a spare before the prices start to go up.
Anyone know if Sony has stopped a-mount LENS production as well?  I assume so, but I have not checked into it.  Are other lens makers still turning out any a-mount lenses???
Curious minds want to know.
    • I’ve just shot a series of perfect shots at 300mm hand held at 1/10s on my Tamron lens with no oss.  I can’t get anywhere close to this with a lens having OSS.  Same thing at 100 with my Sony 24-105.   I am beginning to wonder whether I have a faulty camera that does not work properly with OSS. Yet the camera is so perfect with lenses that do not have OSS, so there is no problem with the IBIS.   Is anyone else having this experience? I find it very frustrating that Sony does not allow you to turn off OSS and leave ibis on, or vice versa. I’m almost wondering if they’ve done this on purpose so that nobody notices that ibis and OSS don’t work properly together. But I would love to hear from others on this topic, because if my camera is faulty, I need to get it fixed.
    • Having the shutter close to protect the sensor is wonderful but it doesn’t work when electronic shutter is on.  Wait!  It does, but that is not the default and you need to be a genius to enable this with silent shutter on….it took me weeks to discover. It’s a hurried feature called “target in silent mode”.  why is there a way to create a shortcut for some things and not others? Like recall memory settings from card.   why are some settings saved to custom dial modes and others are not? For example I shoot with back button autofocus by disabling focus’s on half-press.  It would be useful to have normal half-press focus and other things saved to a custom mode for when I hand my camera to someone who is not used to back button, but stupidly Sony decided arbitrarily that this would be one of the few things NOT saved to a custom mode.  Why?..?   No reason.      these little things really bug me when I just spent 5k on what I hoped would finally be a perfect camera.  These things add up.   Please add to this list and maybe Sony will listen and update the firmware .
    • Given the additional info, if you want to travel reasonably light and have one lens that can do a little bit of everything, the Tamron 28-200 is the best option. Reasonably wide (and fast) at 28 mm end to deal with urban environments and landscapes and long enough at the tele end to allow you to isolate elements in the landscape when hiking.
