I just picked up an A7 and shot it in Aperture priority mode for about 2 days. All of a sudden (i don't know if my finger slipped and touching something?) but images shot in A mode are EXTREMELY slow at processing the images. I hit the shutter then it takes between 3-30 seconds to process the image, which obviously makes the image come out extremely blurry. It almost seems like a long exposure so i initilized and reset the settings and tried it again - seemed OK at close shots. when i tried it again with longer shots, it would do it again.
When i shoot in AUTO or Manual, seems OK. Shutter priority mode is a hit or miss. I really enjoy shooting in Aperture priority - help!
Firmware is v 1.20. I have yet to upgrade to 2.00 becuase I have a MAC.
You can also upgrade to v 2.00 if you are running OSX. Go to the support page on the Sony website and install OSX driver installer.
  • 3 years later...
  • 6 months later...
Hi all,
I was having the same issue. I discovered that by turning off 'long exposure NR' (noise reduction when shutter speed is long) I am not having anymore such long processing time.
Not sure what kind of compromise I'm making here, but so far it works.
Good luck!
There is no compromise for "normal" shutter speeds.
If I remember rightly, Long-exposure NR  takes a black frame, with the same shutter speed, and uses it to compute and reduce the noise in the image. Thus, it always takes at least twice the shutter-speed period. A shutter speed of 15 seconds will take at least 30 seconds to process.
Working backwards, if your camera is taking 30 seconds between shots, the shutter speed must have been around 15 seconds.  Thus your blur.
There is a minimum shutter speed at which your camera will do this process. at higher (normal daylight) shutter speeds, the setting is not relevant. On my a6500 it is 1 second. Googling Long-exposure Noise Reduction and your camera model should take you straight to the manual entry
Edited by Thad E Ginathom
  • 9 months later...
Hi Buddies......
I am new to this blog......!
I am having the same old problem too with my a7.
All those suggestions did not work . As for the Iso setting it too did not ring the bell. I did a shooting in broad daylight setting at Auto Iso and it happened too,,,,, a delay of app 20seconds in processing ( as if it was on a Self-Timer mode ) and a shit picture was recorded.
I must highlight that this happened in Ad hoc basic not always ......
Body Firmware : 3.2  Lens : 01
I am always in  " M " mode operation.
Any NEW discovery in solving the subject matter.....?
bob lee
I'm a bit confused with the question.
Is the shutter speed too slow (ie; a long exposure which allows the picture to blur) or is the processing too slow (ie: are you getting bored, or concerned you're going to get the next shot)?
If it is the first problem, I would suggest viewing a video such as https://chrisbrayphotography.com/courses/online/
I'm no expert, but...
If it's the second problem it sounds like the long exposure NR,  - in which case turn it off and do any noise reduction in post processing.
Or, how about any of the other fancy options such as HDR, DRO or even shooting RAW+JPEG, - the more things the camera is asked to process the longer it will take
  • 2 months later...
  • Long Exposure NR will almost certainly be the cause. It is important to understand that while only applies NR to JPEG images, even if you shoot RAW it will still apply NR to the JPEG thumbnail which is embedded in the RAW file. So, if you do shoot RAW then turn NR off and then do any NR needed in post..
Edited by alasdairmac
