Hi all,
I just tried my brand new sony a7 iv yesterday. I was recording long takes in 4k 25p and to my surprise it kept quitting in the middle of the recording in various intervals (sometimes 5 minutes, others 20). It kept giving overheating warning notifications, but the temperature in the room was pretty standard and the camera body did not feel warm to the touch. I tried 2 different batteries, one sony original and a second from another brand, as well as the usb c ac provided with the camera, but I saw no improvement. This camera should in theory be recording up to an hour of uninterrupted video. Any idea what might be causing this and how to fix it? Any input is very appreciated!
I just got my A7iv this week and was doing a test to check how the battery was doing, with the Sony battery in the camera and the camera powered on.  I was doing anything else with the camera, but when I picked it up a while later (maybe an hour later) I was surprised that the camera was warm to the touch.  Not really hot, but just warm.   I've had a used A7 i and still have a used A7ii, and I haven't seen that happening with either of those cameras.
    • Do you know anything at all about photography, cameras, etc., or was this a purchase because of the trip? If this is your first entry into photography, ignore everything anyone tells you about settings, it will just confuse you. Put the camera in Auto and shoot, you'll be much happier.  Conversely, if you know about such things as shutter speed, apertures, ISO, Depth of Field, etc. etc., then you should already know that there is no such thing as a 'best setup' for an outing that will vary a widely as a safari. You will encounter everything from action to static shots, landscape, light, dark, the entire gamut. If it we me, I'd shoot in manual and make adjustments for each setting.  My wife and daughter went on Safari a year and a half ago. My daughter took her Nikon. My wife is not a camera person so I sent her out with a Kodak Easy Share 16MP something or other set on auto and told her to just press the button. We have several of her shots framed in 8 x 10.
    • Could be a good travel lens I guess. I'd wait until there are some reliable reviews.
    • You have left it until the last minute. I don't know much about the a6000 but I'd be using Manual mode with Auto ISO. Is it Africa you are going on safari? If so, I imagine there will be plenty of light most of the time. You need to set a shutter speed to freeze any action. I would probably start with 1/1000 sec. and set aperture to just below maximum and let the ISO get the correct exposure. Take lots of shots and keep checking to see if you are getting the results you are after. Good luck.
