i am having strange focus issue with my brand new A7SIII. I didn't notice it until i used my slider. Close up shot with any prime lens create this micro focus jitter (don't how to name this issue). I tested my A7III and focus is butter smooth. This is visible on a big screen. So don't watch it on your phone.
This happens a lot using a slider or gimbal (close up shots).
It is scaled to 300 to see the jitter better (lens 24mm 1.4)
https://youtu.be/cHA9l8HSM7s
Firmware: 1.02
Settings:
XAVCS 4K 60P 4:2:2 10 Bit
Continues AF (Video mode Cine gamma 4)
AF transition speed : 4 (i also tried it with lower and higher values)
Af Subject Shift Sensitivity : 4 (i also tried it with lower and higher values)
I tried all the focus and speed value combinations but no change. I disabled the touch tracking, focus are (S,M,L and expended focus) and I reset the camera settings and no luck.
Lenses I tried :
Sony 50mm 1.4
Sony 24mm 1.4
Zeiss 55mm 1.8
Zess Batis 85mm 2.8
Recording or not recording doesn't matter so it is not a SD card issue (I use Sony v90 cards).
A7III works perfect. If it looses focus, it catches it smoothly. A7SIII catches jumpy (regardless any setting).
This also happens on eye tracking focus as well.
I found two topics online about this. They didn't post a solution. I contacted Sony and waiting a call in a day or two.
If any one can test this, that will be super helpful.
  • 4 weeks later...
  • 2 months later...
It's been 1.5 years since I encountered a similar glitch on the A6300 and A6400. Lens stabilization does not matter. Appears on different Sony autofocus lenses (16-50, 35, 50, 18-105 and others). It doesn't matter if the camera is on a 3-axis stabilizer or just on a tripod. Even movement in the frame doesn't matter. The problem appears even when the frame is static. I have always set the focus speed to the slowest setting for video. Resetting the camera does not help.
I am afraid it is the obsolescence of the camera or a miscalculation of the engineers, capacitance sagging on the electronic board and as a consequence malfunction. I have found that even new glass out of the box behaves this way with these tubes.
Yeah I made two topics and I am so surprise they still didn't fix it. More surprise nobody notice like how.. This is so big and no more posts? I don't get it. Don't worry it's a general issue. I tried it with every a7s3 I got to my hands. It's global bug.. Hopefuly they will fix it  soon since on detail shots I have to use my old a73..
  • 11 months later...
Firmware: 1.02
Settings:
Lenses I tried :
Sony 50mm 1.4
Sony 24mm 1.4
Zeiss 55mm 1.8
Zess Batis 85mm 2.8
Yes I can confirm this issue. This happening from day 1. I was from first people to have  this camera since relese and I noticed this like in few seconds of using it. I was like ok this will get fix fast this is a big issue but no.. I made multiple posts and nothing. 2y later and it's still bugged like hello Sony?!!!
Doesn't matter what speed you have. With detail lenses this happening all the time. And to be honest it's really making my job hard.
PLS FIX this! - new update doesn't help btw still bugged.
  • 1 year later...
Hi, did any of you manage to solve this issue by updating to the latest 3.01 firmware for the A7S3 body? I recently got the PZ 16-35mm F4 G lens on my A7S3 body, it also has the same issue, my firmware is still 2.11 for your information
Edited by lunag
Auto-focusing with macro lenses has all sorts of problems.  I'm not going to list all of them -- that would take a book.
That's ONE of the reasons many people use manual focusing mode -- and like me, that's why lots of macro shooters use older, manual-focusing lenses for macro work.
Sony a-900 with Minolta AutoBellows III with AutoBellows Rokkor-X 100mm f4 lens: -- no artificial light, filtration or manipulation:
Edited by XKAES
  • 4 weeks later...
    • Hi all, For about the last 1.5 years I've been using the Sony a7CR combined with the 24-50mm f2.8 G lens as one of the lenses that basically lives on my camera. Besides this I have the following lenses as well: Sony 16-25mm f2.8 G Sony 14mm f1.8 GM Sony 40mm f2.5 G Sigma 85mm f1.4 On my last travel I took the above mentioned lenses with me + the 24-50 G. Would have most likely taken the Sony 14mm f1.8 GM but I didn't own this yet at the time. For my next travel I do want to take this as well so then my setup would look like: Sony 24-50mm f2.8 G Sony 16-25mm f2.8 G Sony 40mm f2.5 G Sigma 85mm f1.4 Sony 14mm f1.8 GM At this point I feel like I'm kinda reaching a bit of a limit in terms of lenses I want to take with me during travel, especially the 85mm. I wish to use it more but noticed I often left it at the hotel/apartment room I was staying at. Initially I bought the a7CR for weight savings but as time has passed I do feel certain limits with the setup especially during travel/landscape (as this is my main form of photography). And that's mainly coming from the amount of lenses I'm taking. I have been considering to trade in the 24-50 G lens to the 24-70 GMII to use on my a7CR but after using my Sigma 85mm f1.4 for an extended time on my a7CR it does feel uncomfortable to use due to the front heavy nature of the setup. The 24-70 GMII would be about the same weight as the Sigma. One option would be to use the extended grip on my a7CR, this certainly makes handling a lot better of bigger lenses but I usually have my setup hanging from the Peak Design Capture Clip on my backpack and I'm not sure if the extended grip really designed to take this much weight to be fair. Maybe anyone here has experience with this? So what this leads me to was the consideration to upgrade to the a7RV + Sony 24-70 GMII as there are some good trade in deals going on right now where I'm at. I'm not sure is this setup an absolute overkill for a hobbyist photographer... :) The benefits of this upgrade would be to have less need for changing lenses during travel and reduce the amount of separate lenses I have to take with me. The overall weight would however be approx. the same that goes in my backpack. Usually when I'm out for hikes I will currently only take the 16-25 & 24-50 with me. With this setup the reach feels limiting even with cropping the 50mm to 75mm (still approx. 26MP on the a7CR after crop). What I usually use my setup for: Landscape photography Travel Portrait Astrophotography I was wondering is there anyone here who went from a lighter a7CR (or similar) setup to a slightly heavier setup to carry around during hikes etc. Did you regret it or was the tradeoff worth it? As mentioned I do feel like my current setup is somewhat limiting and realized that switching lenses during travel is an absolute pain in the ass. But I'm not sure if the extra 450gr (about 1 lb) is worth the tradeoff. I know the decision is ultimately up to me but just like to hear your thoughts on this upgrade, and if the additional features & image quality in trade for weight would be worth it as well. TL;DR: Looking to upgrade my a7CR 24-50G f2.8 setup to a7RV with 24-70GMII f2.8 lens, not sure if it's worth it with the additional weight in trade for more versatility and better IQ. Thanks in advance for your replies!
