Sony A6600 - WiFi Connectivity Issues
Has anyone managed to successfully use the "View on TV" feature? I am unable to get it to connect to a Roku 3. I recieve this error. I'm not exactly sure what "DMR" is. I can't locate any information online. Is this a feature of the camera I can turn off?
Also, the "Ctrl w/ Smartphone" feature won't connect to my Samsung Note 8 using Sonys Imaging Edge Mobile app. So far no luck with WiFi on this thing. I'm new to this camera as of yesterday and the viewing the camera on a TV is important for what I need it for.
  • 1 year later...
