I played around some more ... different phones ... different os etc
finally got an older iphone6s under ios13.6 to connect using imagingedge 7.4
android no way for imagingedge but the older playmemories 6.3 works on an older tablet even
finniky little thing ?
Ahhh you're a lucky one!  ?
A couple of the phones I tried was a Nokia6.1 Android 8 and a LGG4 Android 6 - both said nope
Maybe it's v7.4?  When I get some time I will back the version down towards 7.2.1 ...
It's just funny the old PlayMemories v6.3 on an even older SonyTabZ with Android 4.4 works ?!?!
Time for the two Campbell soup cans and a string ... good grief ?
I vaguely remember there being some reason why I didn't upgrade to the latest.
I also vaguely remember having a hard time getting the connection going first time, and being raltively easy after that.
There are third-party remote apps, but I suspect that if you want stuff like the GPS co-ordinates transmitted to the camera, you need the Sony app up and running reliably.
    • Do you know anything at all about photography, cameras, etc., or was this a purchase because of the trip? If this is your first entry into photography, ignore everything anyone tells you about settings, it will just confuse you. Put the camera in Auto and shoot, you'll be much happier.  Conversely, if you know about such things as shutter speed, apertures, ISO, Depth of Field, etc. etc., then you should already know that there is no such thing as a 'best setup' for an outing that will vary a widely as a safari. You will encounter everything from action to static shots, landscape, light, dark, the entire gamut. If it we me, I'd shoot in manual and make adjustments for each setting.  My wife and daughter went on Safari a year and a half ago. My daughter took her Nikon. My wife is not a camera person so I sent her out with a Kodak Easy Share 16MP something or other set on auto and told her to just press the button. We have several of her shots framed in 8 x 10.
    • Could be a good travel lens I guess. I'd wait until there are some reliable reviews.
    • You have left it until the last minute. I don't know much about the a6000 but I'd be using Manual mode with Auto ISO. Is it Africa you are going on safari? If so, I imagine there will be plenty of light most of the time. You need to set a shutter speed to freeze any action. I would probably start with 1/1000 sec. and set aperture to just below maximum and let the ISO get the correct exposure. Take lots of shots and keep checking to see if you are getting the results you are after. Good luck.
