Hi everyone, been away for quite a while.
My old but trusty A6000 only goes to 1/60 instead of 1/160 for flash sync speed. Firmware is up to date and I use all Godox (flashes, transmitters, receivers, etc.).
Anybody knows what is going on or has experienced this issue before?
Thanks!
Hi FWC, thanks a lot and I get your point but that wasn´t the issue. BTW, the A6000 has mechanical and electronic first curtain but only mechanical second curtain and it doesn´t affect the sync speed either way, that I noticed.
Turns out that it was the flash I was using with that camera. I updated the firmware (again) and problem solved, It goes to 1/160 now and works just fine.
Thanks a lot for your help!🙂
