As the owner of an NEX 7, I would like to be able to mount the very good Sony A 16-50 f 2.8 SSM lens, and am confused as to which Sony adapter to use - there are 4 I believe - 2 for full frame E mounts and 2 for APS C E Mounts like the NEX 7.
This lens has a focus motor built-in so I was a bit confused when a B&H sales guy said in order to have the lens auto focus on the NEX, I would need the LEA 4 adapter which has a focus motor as well - with that set up I would have 2 focus motors? That sounds wrong. That motorized adapter also seems to be for the full frame E mounts like the A-7...?
I understand this lens can be used manually to focus with "dumb" adapters like the one I use for my manual Nikkor lens.
If anyone has any insight into the best way to make that lens (or any A mount lens) work with the NEX 7 (and retain auto focus) please let me know.
Thanks,
Robert
 If the lens has an internal focus motor and the NEX-7 has an APS sized sensor, the lowest priced LA-EA1 will work just fine. :)
LA-EA1 APS sized opening for a-mount lenses that have internal focus motors or both SAM or SSM lenses
LA-EA2 APS sized opening for a-mount lenses that have the camera driven focus mechanism. The LA-EA2 has a transparent mirror and drive motor in it for focusing with older mechanical lenses. it will also work with SAM and SSM lenses.*
LA-EA3 Same as the LA-EA1 but with Full Framed opening
LA-EA4 Same as the LA-EA2 but with Full Framed opening.
ALL will work with the NEX-7 and the SAL1650.
If you intend to some day get a full framed e-mount camera and possibly use older A-mount mechanical lenses, then the LA-EA4 is the way to go.
* Occasionally Sony will have firmware lens compatibility updates for use with the LA-EA2 and LA-EA4
Side note: I once owned the SAL1650 f2.8. If is for sure a very good lens.
    • From my records, Minolta made about 8500 85mm F 1.7 lenses bearing the MD badge. The MC-X version was slightly double that. So these are not that rare. I just saw an ad for a Limited Rare MD 45mm F2 lens ( Minolta made over a million of these) so the word rare is often used in a bizarre way. Seeing that the OP has a MD ROKKOR-X version and that he appears to have bought it from Europe is kind of unusual since the ROKKOR-X versions were to be sold exclusively in America. So in Europe, this lens naming was rare.  I think the confusion about a reworked version may come from the fact that during the MC-X era (1972-76), Minolta made numerous changes to their lens line-up. First they changed the lens Mount Index dot which was initially painted like their previous series of lenses but after about 1 year, they replaced this with a slightly larger diameter plastic bead. This change happened around the introduction of the X-1, XM, XK bodies. Then they removed the small Stop Down Levers that were on most lenses up to now around 1975 since their SR T and XK/XE bodies were now boasting a Stop down mechanism. Then a little later Minolta even removed the lens formula (in this case PG) designation from the lens markings. This may have caused people to believe there was some kind of modification to the lens when it was only a marking  change. Also around 1973-74 they decided to provide a different marking for lenses sold in America ( at least USA and Canada) to identify lenses sold on the grey market that was often cause for confusion with consumers buying a great deal they could not get repaired under warranty. Same applies to Bodies starting in the same era where  X-1 was for Asian market, XK for American market and X-M for rest of the world, then SR T 102 in America, SR T Super in Asia and SR T 303 in rest of the world. So you could find all of the following with their respective front markings: - MC-II: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL) This type has the hills and valleys metal focusing ring -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL and Painted Lens mount index changed around 1973-74) -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with SDL and Plastic Bead Lens mount index changed around 1973-74) -MC-X: MC ROKKOR-PG 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index ) -MC-X: MC ROKKOR 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index and no more PG lens formula index) -MC-X: MC ROKKOR-X PG 1:1.7 f=85mm ( with SDL and Plastic Bead Lens mount index, Orange colored ROKKOR-X marking for the American market) -MC-X: MC ROKKOR-X PG 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index, Orange colored ROKKOR-X ) -MC-X: MC ROKKOR 1:1.7 f=85mm ( with No SDL and Plastic Bead Lens mount index and no more PG lens formula index, Orange colored ROKKOR-X) -MD-II: MD ROKKOR 85mm 1:1.7 ø55mm -MD-II: MD ROKKOR-X 85mm 1:1.7 ø55mm (Orange colored ROKKOR-X again for the American market) -MD-II: MD ROKKOR-X 85mm 1:1.7 ø55mm (White colored ROKKOR-X ( iguess orange paint was getting too expensive) ) It was then replaced with the MD-II MD ROKKOR (X) 85mm F 2 There was no MD-I version of this lens and the same with a few lenses with large apertures ( 35mm F 1.8, 58mm F 1.2, 300mm F 4.5) since they had issues with the speed of the aperture mechanisms closing down for what was  a last minute check on XD/XD-7 and XD-11 bodies requiring stopping the lens down just prior to the shutter opening to ensure accurate exposure. Some late MC-X lenses may have had the modified aperture mechanism causing the confusion that there was an updated version but the optical formula seems to indicate there was no change.
