  • 6 months later...
Lets get something straight. It can shoot true 4K...not fake 4K from a phone. Even RED cameras have bigger issues ( like cropping files to 4gig ) then the SONY series do. Another issue ( even if you could get 60fps ) is over heating.
These cameras need heatsinks. Big video-cameras are big because they literally are giant heat-sinks to move the heat away from the camera.
That spot where the display pulls out could be used to apply a heatsink.
Then you could program 60FPS into it among other things.
  • 5 months later...
agreed, wonder if those 4k 120fps rumors are true about a7siii
