Vertical banding with A7RIII during strobe use
Hey guys,
I'm not a studio expert, and am struggling to figure out what is causing vertical stripes/banding on my paper backdrops when using strobes. Color or white, doesn't matter. I'm using the flashpoint/godox ad600 strobe with HSS turned on and shooting (in my attached example) at 1/1250th and ISO 100. This has happened to me numerous times now, and I haven't been able to detect a pattern yet. I haven't tried turning off Electronic Front Curtain yet, but will next time. It's only noticeable on paper backdrops (or maybe any plain surface), but not on my subjects.
Any ideas?
Thanks!
Two thoughts:
1) Flicker from the HSS strobe. Try normal sync speed.
2) Compression artefacts from your raw converter or in-camera jpeg engine. Try uncompressed raw in CaptureOne.
Two thoughts:
Thanks Jaf, appreciate it! I'll try normal sync first. Hopefully it's not artefacts...would definitely mess my workflow up a bit (using LR on compressed RAWs)
Ok, hope it works out. You could try opening the same compressed file in C1 just to compare. If It's artefacts, they should be less visible thanks to the better raw conversion.
I don't think that's the best workflow to go with anyway. You have to just bite the bullet and go uncompressed. I haven't used LR in years but why not try Capture One, I think there's a free version for Sony.
There are reasons to use LR. Catalogueing, calibration, printing, presents and overall fast editing.
Other programs like C1, PS or DxO give better results on individual photos. But they're a bit of a pain if you have to turn out a large number of photos.
I still haven't been able to drop LR even if I loathe the direction it's taking.
I just tried editing the same shot in C1 and unfortunately it's giving me the same results. It's not the raw engine, so it must be either the sensor itself or the strobe/way i'm using the strobe. Hmm.
I'm in the same boat!
Well, strobes emit pulses of light in HSS mode so that could be the issue. At standard sync it's just one flash so that may be the difference.
That very well may be true. Or the combination of HSS with ECFS. Found this flickr group chat regarding another Godox product with HSS and an A7 camera: https://www.flickr.com/groups/71917374@N00/discuss/72157642684407174/
I'll have to use it without HSS or without EFCS next time and hopefully won't have the issue. I guess for most studio scenarios, I wouldnt need HSS anyway...
Disabling the electronic first curtain usually mitigates banding issues from the sensor readout/flicker but it may not remove it altogether in all situations. That said, I mostly shoot with shoot old school settings, like with film, and never have any issues related to the technical envelope of the cameras.
HSS is primarily for outdoor fill light where outdoor shutter speeds
are typically faster than native synch speeds. In such applications
the pulsed nature of HSS lighting is greatly masked over by the
overwhelming amount of daylight [which acoarst is not pulsed] in
the total lighting mix.
In general, most user manuals I've read recommend mechanical
shutter settings for all modes of flash use.
What exactly is the electronic first curtain shutter? Benefits of either on/off? The Sony explanation isn't too clear to me.
The mechanical shutter is still needed to reduce issues such as banding and rolling shutter effect from the sequential readout of the sensor. The second curtain, which ends exposure, is more important in this regard. Therefore you can disable the first curtain (by enabling electronic first curtain). This reduces shutter lag, noise, shutter shock and wear on the shutter.
