Sony SNC-VB770 network camera
200sx
Not really a run of the mill question but I wonder if someone can offer advice.
We are trialling a SNC-VB770 network camera with E mount at work with a view to buying.
We would like to use our existing collection of Nikon F mount lenses - a mixture of Nikkor, Sigma and Tamron, and this may determine whether we buy into the technology.
We don't need auto-focus, just an adapter that works reliably with a wide range of Nikon mount lenses.
Which is likely to be the best adapter for our needs?
TIA
