Fine Art Photograph with Sony A7R2
vincentminorphoto
I shot this image titled "A Thousand Rooms" at an abandoned hospital in NY with the Sony A7R2 and the Canon 50 1.2 Lens. I wanted to show how painterly you can create with this camera, it's tones are gorgeous out of camera and a joy to play with in photoshop because it's high resolution and the tonal range in shadows. Thank you! Hope you enjoy! Follow my work at facebook.com/vincentminorphoto or instagram/vincentminorphoto
